ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Interior light question
Old 08-26-11, 08:07 PM
nevernu
nevernu's Avatar
Default Interior light question
What does #1 mean in plain english?
What does this #2 mean/control? And why if I press 2 on , the lights go on and eventually all go off except the rear dome lights which stay on ???
Old 08-28-11, 02:01 PM
nevernu
nevernu's Avatar
ok over 60 views and no answer???
i'll make it simpler! what does #2 do????
Old 08-28-11, 05:19 PM
oldgrump
oldgrump's Avatar
The switch with the "car/doors" icon on it when pressed in (locked position) enables the entry light (with fade) system which operates when you open a door. When the switch is "out" the entry light system is disabled. The switch with the "light" icon on it is simply an on/off switch for the two front overhead (reading) lights and rear dome light. Not sure when it occured but these two switch locations are reversed on my 2011. Test them out.......sit in the driver's seat and operate the switches and open/close your driver door etc. That's how I figured them out. The lower door panel lights and foot well lights will always come on when a door is opened......at least with my 2011.
Old 08-28-11, 08:54 PM
nevernu
nevernu's Avatar
Thank you for your clear reply.
/so those little dinky slits in the black thingie are reading lights are they???
Old 08-28-11, 10:05 PM
oldgrump
oldgrump's Avatar
No.....the "reading/personal" lights on your car are the bank of LED lights (3 each side) on your overhead console......these were changed to a single incandescent bulb (each side) in 2010, I think. The two small LEDs that you have in the "black thingie" (my 2011 has only one) and their purpose are shown on another page of your Owner's Manual. On mine, the single LED there lights up the gear selector under certain conditions. I know your 2007 has a different rear dome/personal light setup than the post 2010 cars.
Old 08-29-11, 05:47 AM
2008ES
2008ES's Avatar
Rarely, I've seen promotional materials for pre-2010 ES refer to "illuminated cup holders." When I was shopping, naturally I looked and never found a light inside the cup holders themselves, but finally realized these two little spotlights are aimed directly at the area.
__
Old 08-17-14, 10:37 AM
acostabj
acostabj's Avatar
Gear selector lights on selector console is not working, not overhead console lights
Old 08-17-14, 01:58 PM
mlacomb
mlacomb's Avatar
Wrong thread.
Old 08-17-14, 05:19 PM
Lexi66
Lexi66's Avatar
What can I say, I can't tell you how many times I have asked similar questions and been
told to check the Owners Manual. Frankly, I find the explanations in the Manual
MOSTLY not understandable!! 😰😱😭😥
tubenut96
11-04-22 08:14 AM
nht48823
HS 250h Model (2010-2012)
12-15-15 11:03 AM
pooleman51
RX - 3rd Gen (2010-2015)
09-21-14 07:15 PM
waeltzy
09-05-12 03:01 PM
oneshote
RX - 1st Gen (1999-2003)
01-20-11 10:15 AM
Quick Reply: Interior light question
