Illuminated Door Sills for 07-09 Es350.
#31
There is an easier way to install the door panels. The way you guys have been doing it bends/breaks the long male tab on the outer corner of the doors and just makes it more of a p.i.t.a.. Here's the easier way:
Reinstall - do with your window down
This is to remove the window weatherstripping piece off the door panel that clips onto the top of the actual door.
Put the door panel on the floor face down - look underneath and up at the piece that clips onto the door
Use a flat head and push in the most middle part of each bare stainless steel connector and rotate the flat head. It will release and push the piece off. (If this is not working you are not catching the tiny metal edge)
Clip it back onto the top of the door making sure the male part of the clips are facing towards you.
Line up the biggest male part on the top right corner of the door to the female part on the door panel. This will line up the top right side. Push in. (RH sides) (Reversed for LH side)
Then line up the push fasteners on the left side. This will align all the fasteners of the door and push/bang on the cover until all the fasteners push in. (RH sides) (Reversed for LH side)
#32
When I did this to my 300zx, I wired mine to the open door switch (black rubber plunger in door jam). I wired the units I bought to a constant power source, the ground was made using the door plunger, where the ground circuit closes when the door was open (plunger extended). If you could wire it there, it might be easier than going through the door? What do you guys think about the quality of these units thus far?
#33
#34
BTW, the quality is very good. The machined metal is on par with OEM. The only complaint is the LED's... I find them a bit too bright and blue (for lack of a better description), I prefer it a bit softer.
#35
4. Took the piece of trim under the seat belt off then u have access to the door wiring.
5. Then you can remove the wiring clip to get access to that socket from the inside of the car and fish a wire thru the rubber piece( I used a fish tape).
6. I ran the wire so it would come out from the sound detination plastic just by where the light wire clip is, it should be a blue and red wire. red=positive and blue=negitave
7. I just tapped into it there so I could solder it without being in the car. You can either hook it all up now and leave the other end of the wire under the sill so it's easy to get to when you get your sills in the mail. Make sure you tape both ends there will be power to the wire.
Good Luck
Feel free to ask questions, I may not be the best at explaining everything but it should all make more sense when you start taking the car apart.
Good Luck
I think I could have just tapped into the wiring clip directly. I saw the red/blue (22 AWG type wires) on the wiring clip. When I tested the doors, it was showing a constant 12V, but I think I was just impatient because there is a delay on those courtesy lights... You may not even have to pull your door skins afterall.
Also, since this kit connects all 4 sills, what did you use as a pass through to get from the drivers side to the passengers side?
Thanks in advance.
#36
So after you fished the wires through the rubber door connector and through where the wiring clip is (interior of car, below seatbelt), did you just re-install the clip after? Its a bit tight with the wiring being pulled through, and I don't want to stress the wire too much.
Thanks in advance.
Thanks in advance.
