Alternator Wiring Diagram
Old 10-03-11, 09:40 AM
adreano17
adreano17's Avatar
Default Alternator Wiring Diagram
need to know, planning to install a HO alt, and want to know the paths of the hot wire of the alt. Looks like it goes into the engine block, and comes out on the other side for the battery connection. . a little confused. thanks. got a 96.
Old 10-03-11, 11:04 AM
EEngineer
EEngineer's Avatar
^that would be the ground ur looking at.
hotwire is in the plug
Old 10-03-11, 12:15 PM
adreano17
adreano17's Avatar
no, whatever bolt is on the other side of the engine for the ground. it is connected to the positive terminal on the battery. the plugs on the alternator? thats just the low voltage light plug....
Old 10-03-11, 01:47 PM
EEngineer
EEngineer's Avatar
^yes sir you are indeed correct!
thanks to you, i had to find out for myself. looks like the body of the alternator is the ground. since it is connected to the block anyway.
Old 10-03-11, 01:49 PM
EEngineer
EEngineer's Avatar
btw, i know the Tacoma Alternator works for the 1MZ, u should give it a try
Old 10-04-11, 09:54 AM
adreano17
adreano17's Avatar
I heard about that one. Its only 140 amps, and i would like ALOT more lol. i was looking into this universal one at powerbastards.com it runs 110 @ idle, and 220 at 1500. (the power i need).
heres a picture in a 2001 camry: http://www.powerbastards.com/images/022310154653.jpeg
The wiring diagram didn't help me understand like i should lol. I was thinking to just leave the existing power wire and also adding a 1/0 wire to the battery (so i will not have to integrate other wires) do you think this is a good idea??
TurbodVq35
05-28-22 11:50 AM
MarcusMIA
Performance & Maintenance
12
10-03-16 09:46 PM
skaendo
SC- 1st Gen (1992-2000)
02-01-14 11:58 AM
98_es300
05-03-09 06:02 PM
steveo81
09-15-08 10:56 AM
Quick Reply: Alternator Wiring Diagram
