ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Mark Levinson Audio?
Old 07-14-14, 04:51 PM
  #646
RayM
RayM's Avatar
Thanks Kenny. The dealership replaced the AMP and it sounds much better. However, now there is hardly any sound coming out of the subwoofer and majority of the bass is coming from the front speakers.
Old 07-23-14, 01:00 PM
  #647
LarES30014
LarES30014's Avatar
Default M L adjusments
Originally Posted by LarES30014
Also, the volume goes up to just about where I like to listen when alone (I like it loud), but no higher at max 62. With my SC430, the volume goes down when the navigation system delivers a message. That's not the case with my ES. Result - I don't even hear the message. Dealer says people didn't like being distracted from their music so they changed it. Bad change as far as I'm concerned.
______________________
2014 ES300h Starfire Pearl, Parchment, Michelin, Ultra Luxury Package (just to get the Mark Levinson)
Since my last post, I have fine tuned my Mark Levinson and now I am extremely pleased with the quality and sound. I set the treble at -3 and the mid at 0 and base at +4. Without adjusting the tone controls, the sound is screeching and hurts my ears at high volume. This thing is WAY too treble happy with very little bass without the adjustments.
Old 07-23-14, 01:09 PM
  #648
Amphibulus
Amphibulus's Avatar
It's disappointing that the sub doesn't work, the doors have to handle all the bass and it makes them vibrate.
My setting is almost flat. I think I'm a 0 for treble, 0 for mid, and +1 for bass. More bass and the door rattle too much.
Old 07-29-14, 07:28 PM
  #649
Mhobizal
Mhobizal's Avatar
I have been extremely pleased with my Mark Levinson system. I do wish that Lexus had included an adjustment for the sub, but I still think this system sounds great. I've spent some time tweaking the levels for the different types of input: USB, Pandora and XM-Radio that I listen too. XM has the worst quality of sound.
I also listen to some of my DVD-A discs that work in my Lexus. I used to own an Acura TL. While it is not the same quality as the Acura, I'm pleased.
Old 09-01-14, 02:46 PM
  #650
nsaldanh
nsaldanh's Avatar
Mhobizal: How are you getting your unit to play DVD-Audio discs? DVD-Audio discs that used to work on 2012 LS 460 are not recognized on a 2014 LS.
Old 09-05-14, 02:43 PM
  #651
Kijug
Kijug's Avatar
I have a '14 ES 350 UL/ML and I think the ML audio is great. Crystal clear. I'm impressed. I enjoy good audio, but not that I go around trying other systems, so.... That said, I've tried every app out there to burn a DVD-Audio disk to play in the car...but the car doesn't recognize any burned disk--even the apps that are really burning DVD-Audio (and not just a DVD with mp3's, etc.) Has anyone been successful at burning a DVD-Audio and using in the ML system?
Old 09-05-14, 03:47 PM
  #652
cavedawg
cavedawg's Avatar
Kijug: Sent you a PM
Old 09-07-14, 07:33 AM
  #653
Mhobizal
Mhobizal's Avatar
Some play and some don't play. You just have to try them.
Old 09-07-14, 08:58 AM
  #654
gappell
gappell's Avatar
This is my second ES with a Mark Levinson sound system and I have never been impressed. Unfortunately, it comes with the UL model.
It requires a lot of tweaking to get a decent sound. Each source requires separate adjustments with those from apps providing the worst quality. I always get the sense that the music is shouting at me from the dashboard. My 2009 Toyota Highlander with standard audio sounds better and provides a surround effect that immerses you in the music.
Old 09-10-14, 04:46 PM
  #655
nsaldanh
nsaldanh's Avatar
DVD-Audio used to work on a 2008 LS and a 2012 LS. None of thise discs will play on a 2014 LS. Lexus took away the ability to play DVD-Audio on the 2013+ LS models. The manuals now specifically say that DVD-Audio discs might not work. In the past they said that DVD-Audio was supported.
I was able to burn a DVD-Video disc with 24 bit 96 KHz PCM audio and that plays without a problem as long as you dont have any images or video, just plain audio.
Old 09-10-14, 06:52 PM
  #656
ElliotB
ElliotB's Avatar
"Has anyone been successful at burning a DVD-Audio and using in the ML system?"
Yes. I have two DVD burners (non-computer) and they both work perfectly.
Old 10-08-14, 05:34 PM
  #657
jbm79
jbm79's Avatar
It took some arguing with my dealer to convince them to change out the amp, but I just had my amp replaced to the new one, and the issue is fixed. As others have noted, more of the bass is now directed to the front door speakers. I will have to play with the settings to even out the bass output and direct some to the subwoofer. But overall I'm satisfied.
As noted in previous posts, new amp part # is 86280-0WA71.
The old amp part # is 86280-0WA70.
Old 10-09-14, 05:15 AM
  #658
jollick
jollick's Avatar
I am glad you were able to resolve the issue.
2019ES350
09-07-20 02:01 PM
wmogolov
ES - 7th Gen (2019-present)
30
12-15-19 03:03 PM
bc6152
68
09-08-19 08:53 PM
wmogolov
31
11-17-18 06:01 AM
Jamiroquai
CT 200h Model (2011-2017)
05-29-16 01:52 PM
Quick Reply: Mark Levinson Audio?
