Navigation system
Navigation system
I have a 2011 ES 350 and want to update the navigation maps.
i understand I need to purchase a 2016 map disc and install it.
In order to do that I need to remove the old disc.
How do you REMOVE THE PLASTIC PIECE under the touch screen so I can swap them out?
thanks
thanks
EDIT: Just noticed you said 2011 ES, that means your navigation is hard drive based. Should be updated via USB.
The gray plastic rectangle with Lexus on it just slides UP. I can just use my thumbs or fingers to press it in (to get a grip) while pushing upwards. You could probably use a putty knife under it but it really isn't necessary (and you could mar the plastic).
NJD1995
ES - 6th Gen (2013-2018)
05-26-21 11:35 AM
