2007 - Lexus ES 350 - Check Engine Light - Code P0161 and P0057
Guys,
Can someone help figure out what is going with my car? A few weeks ago, the check engine light and the VSC light came on. Just yesterday, I took it to autozone to scan for codes and P0161 (heated oxygen sensor - bank 2 sensor 2 and heater circuit malfunction) and P0057 (oxygen sensor control circuit low 22) came up as the codes causing the problem. Any ideas on what caused them and how I can fix them? I am beyond my factory warranty period so I rather fix it myself as the dealer will charge an arm and a leg.
Thanks!
Thanks!
Hello, I have the same code popped up on my dash P0057 and P0161 with CEL, VSC on and Tracktion light on as well. So I figured it was just an oxygen sensor Bank 2 Sensor 2. I will be working on it next week, so I will let you know if this solves the problem. Let me know if you had yours done and what you did to fix the problem. Thank You
