can anybody tell me what this noise is???
Old 08-28-14, 06:42 PM
Hayk
Hayk's Avatar
Just got to see the video. Holy crap that sounds awful. It's like your exhaust system and wheels are falling apart.
Old 08-29-14, 04:31 AM
jc2005
jc2005's Avatar
yea i know and it feels even worse....
Old 08-29-14, 07:45 AM
hanime
hanime's Avatar
Any update from the shop?
Old 08-29-14, 12:27 PM
mouse23
mouse23's Avatar
Default Master cylinder failure?
Just my thought from experience.
When releasing the brake, the master cylinder at its rest position should release the pressure through a little hole so the pads can back off a little.
I had this function fail on my mercedes once and I could smell something burning. When I stopped to check, my front disks were cherry red from the heat. I had to replace the master cylinder.
What can make the car shudder is that those discs at this temperature may distort.
Old 08-29-14, 12:34 PM
jc2005
jc2005's Avatar
he couldn't determine what it was so i'm going to take it to another shop and see if he can figure it out
Old 08-29-14, 05:29 PM
Hayk
Hayk's Avatar
What is the warning light on your dash?
Give this a shot - put the transmission into Neutral when you get that noise and see if you notice a change.
It seems like your brake pads are always engaged against warped rotors. When you're cruising, they're hitting the rotors and causing such a horrible noise/vibration. The vibration worsens when you apply the brakes. I would check the calipers to make sure they release all the way back and allow the front wheels to spin freely.
Like mouse23 said, they could also be stuck due to a bad master cylinder.
Old 09-05-14, 11:26 PM
ES300NZ
ES300NZ's Avatar
I was thinking about this today (God only knows why, but I was). I think I might have the answer. It's a tyre problem.
I know what you're thinking, wtf. No seriously, I think this is what it is: a (or both fronts) tyre has de-laminated internally, the steel belts and the nylon belts, etc, have de-bonded inside. You could look at the tyre and even examine it and never know. But if you got it up to a specific speed all hell would break loose because of the centrifugal forces.
There are a few causes for this, but sometimes it's just bad luck. It's quite rare, but common if a car has been sitting a very long time without moving much. Heat and time do it, so does a manufacturer fault.
A free way of figuring this out would be to swap fronts to rear, and rear to front. OR, borrowing some replacement wheels.
joshua28
Suspension and Brakes
13
02-26-19 06:40 AM
LexIS03300
IS - 1st Gen (2001-2005)
03-30-18 01:04 PM
lex460l
09-22-14 05:50 AM
xuningshen
03-24-10 09:29 PM
ScCrazy
03-01-06 04:08 PM
Quick Reply: can anybody tell me what this noise is???
