air suspension tank
Old 07-23-14, 02:05 AM
needhelp21
needhelp21's Avatar
Default air suspension tank
Where do you put the air in at on an 95 Lexus ls400? Is it under the hood like to the right side of the engine? Is it an wire with an screw off top with an "L" on the top?
Old 07-23-14, 02:25 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
what in the blue blazes are you trying to do?
You aren't supposed to need to "add air" to anything in the LS400 except the tires, and there is no provision to externally fill the factory air suspension tank.
Old 07-23-14, 03:20 AM
needhelp21
needhelp21's Avatar
Just asking. The left side of my car lean mostly the rear. It lift up every once in awhile. I want to know what i can do about it.
Old 07-23-14, 07:59 AM
Caniac14
Caniac14's Avatar
If you have factory air suspension then it's not a matter of needing air. Something is wrong with your level sensors, or the bags have leaks and the car keeps trying to fix it by pumping them back up.
Old 07-23-14, 12:04 PM
needhelp21
needhelp21's Avatar
Ok.
How or what i need to do to fix it? If its even fixable.
Old 07-23-14, 06:21 PM
Caniac14
Caniac14's Avatar
The first thing I would look at doing is getting soapy water and putting them all over the bags onthe side of the car the keeps falling/leaning and look for bubbles. If bubbles form you have a leak. If not then I would look at the sensors. Although the fact that the car keeps pumping air back into the mags makes me think the sensors are fine.
Old 07-23-14, 06:22 PM
Yamae
Forum Moderator
Yamae's Avatar
Originally Posted by needhelp21
Ok.
The replacement is needed in most of the cases.
Old 07-23-14, 11:08 PM
Shmee
Shmee's Avatar
buy NEW suspension, remove old parts, install new parts. fixed
Old 07-24-14, 12:26 PM
OKSTANCE
OKSTANCE's Avatar
you should have also thrown in the words: sassafras, ya'll, and partner.
r0cketm0nk
04-16-17 03:57 AM
pearlcity
03-04-10 12:15 AM
PlutoBHG
Maintenance
06-01-05 12:52 AM
1forlexus
10-18-04 10:12 PM
Quick Reply: air suspension tank
