AV port distorted
Old 07-18-14, 09:23 PM
janterry15
janterry15's Avatar
Default AV port distorted
So I plugged in my 4 pole into the aux port and I tested it using 2 different cables I have as well as testing 2 different DVD players on the TV to confirm.
I can't seem to get a stable image. I tried every combination of colors.
The only way I was able to get anything close to getting a stable image is if I were to pull the 4pole outward on the aux port and hold it still with my hand but that will have no sound + picture is still crappy.
What am I doing wrong?
Old 07-19-14, 12:07 AM
Dark9t316
Dark9t316's Avatar
Possible that you have damaged ports, check with the dealership.
Old 07-19-14, 08:22 AM
dojoman
dojoman's Avatar
You have wrong cable. There are two types of 4-pole cables. You must have the one with longer connector because if you plug all the way in only part of connector is connected. I will post pic of the correct one I have later.
Old 07-19-14, 03:26 PM
janterry15
janterry15's Avatar
Do you know what's it called? Thanks
Old 07-19-14, 04:54 PM
dojoman
dojoman's Avatar
It's this one. Incorrect one has ground pin longer and when you plugged into the jack it passes through connector where it should have stopped. That's why it kind of works when you didn't plug it all the way.
http://www.ebay.com/itm/301090455130?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old 07-19-14, 08:28 PM
janterry15
janterry15's Avatar
Thanks! I sure hope this will fix the problem and not that my aux port is damaged...
Old 08-12-14, 04:46 AM
Mesh704
Mesh704's Avatar
U didn't tell us is it the right one !! I'm not from the U.S and I'm about to order one from eBay and will cost me too much for the shipping, I just wanna make sure it's the right one !!
I have an iPhone 5s what should I buy to watch movies from my phone while I'm driving?
1- beatsonic
2-
3-
Can y'all tell me !!
Thanks
Old 08-12-14, 08:35 AM
dojoman
dojoman's Avatar
1- beatsonic
2-
3-
Thanks
Yes, it's the right cable but not for iPhone. There's a way to watch from iPhone but it's not worth it since you need digital to analog converter, iPhone video come thru digital connection but Lexus AV port is analog.
Old 08-12-14, 01:37 PM
Mesh704
Mesh704's Avatar
So what should I do to mirror my phone on the screen ?
Old 08-12-14, 02:04 PM
dojoman
dojoman's Avatar
For now you can't but Prestigious Society is making a box that will accomplish this but not sure it's coming to 3IS. You can contact them.
http://www.prestigioussociety.com/?p=1376
Old 08-12-14, 02:41 PM
Mesh704
Mesh704's Avatar
Thanks and I will email them !!
Bolosdad
09-29-14 07:51 PM
vncasanova
10-14-13 12:31 AM
jg 368 48
RX - 1st Gen (1999-2003)
05-08-07 08:54 PM
blissful
ES - 5th Gen (2007-2012)
26
10-16-06 01:26 PM
SFox
07-10-03 09:26 PM
Quick Reply: AV port distorted
