heat inside cabin
Old 04-30-14, 09:05 PM
rohanstar
rohanstar's Avatar
Default heat inside cabin
i have an 08 AWD, at 60 - 70 mph it gets hot inside my car does anyone experience that
Old 04-30-14, 09:14 PM
Raybean
Raybean's Avatar
I had that even with the heat off hot air could blow from the vents. Never check if this was normal or not.
Old 04-30-14, 09:33 PM
Serifiyah
Serifiyah's Avatar
Yea same here. My guess is because of my broken servo arm inside the cabin air filter.
Old 04-30-14, 10:25 PM
my1s250
my1s250's Avatar
if you have air off and the have the air recirculate to have outside air come in then yes you will get hot air blow in if its warm or hot outside
Old 05-01-14, 12:49 AM
Serifiyah
Serifiyah's Avatar
My car is stuck in fresh air mode because the previous owner improperly replaced the cabin air filter and broke the servo arm. When i have the AC off, sometimes I get that hot air flowing in. I just turn the AC on, turn down the temperature, then turn it off. No more hot air.
Old 05-01-14, 11:20 AM
rohanstar
rohanstar's Avatar
Mines only get hot at top speed otherwise it don't so i don't think it has anything to do with the AC and that's when my heat and everything is turned off, it might be from the ingine and all the work its doing + I live in NY so I brake a lot so I think that can cause it as well
Old 05-01-14, 11:59 AM
NYKnick101
NYKnick101's Avatar
TURN DOWN THE TEMPERATURE!
even if the fan is off and you have it in fresh air/ mode, the heat coils still get warm and will make the cabin warm. The heating system needs to prepare for that moment you DO decide to turn on the heat to have instant warm air. If you turn down the temperature, it doesn't get warm when on fresh air. I think this applies to MOST cars because every car i had was like that. If the temp was still on 80 but the fan is off, when in fresh air mode it will still get warm. Turn the temperature down it will be cool fresh air
williex
08-20-17 08:49 AM
600rr
06-15-17 02:49 PM
wise2k
06-27-13 07:17 AM
LenniePaz
04-04-12 01:10 PM
teefbee
07-04-11 11:40 AM
Quick Reply: heat inside cabin
