Old Dec 15, 2014, 04:03 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
Replaced battery now Power Windows don't work
Old Dec 19, 2009 | 06:03 PM
jbyham's Avatar
jbyham
Default Replaced battery now Power Windows don't work
I had to replace the bulb on my drivers side headlight in my GX and in doing so had to take out the battery. Everything went fine until I put it all back together, turned the car on and now my drivers side window controls don't control the other 3 windows in the car. AND none of the windows are performing the auto down function. If it matters the little green light on the window switches themselves are blinking.
Just to summarize:
1. Took battery out
2. Put batter back in
3. Drivers side Power window switches don't control other three windows.
4. Drivers side switch controls drivers side window
5. All switches control their individual window
6. No switches are performing the auto down function
And yes, I checked to make sure they weren't locked.
Help please. Thank you
Old Dec 19, 2009 | 06:05 PM
EyeKutr's Avatar
EyeKutr
Read your manual or search "battery windows"
Old Dec 19, 2009 | 06:46 PM
jbyham's Avatar
jbyham
Checked my manual and have searched battery windows, power windows, etc. Can't seem to find anything on a solution. Any ideas?
Old Dec 19, 2009 | 08:03 PM
nmmuzykam's Avatar
nmmuzykam
You need to lower each window one at a time by actually holding the switch (not auto up/down) and then raise the window up. You need to do this in the following order (on the switch on each actual door, not the master panel)...driver's, front passenger's, rear passenger's, rear driver's. I may have mixed up the last two, but you will be able to tell since the switches won't work unless done in the proper order...hope this helps! BTW, you need to do this every time the battery is disconnected for more than 5 minutes, for future reference.
Old Dec 19, 2009 | 08:10 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
There is a link in the 2nd gen IS FAQ that will help (looks like nm has it above already). May also need to do it on moonroof.
https://www.clublexus.com/forums/is-...isconnect.html
Old Dec 19, 2009 | 10:57 PM
slvrpine03's Avatar
slvrpine03
they need to be "normalized" just search "normalize windows"
Old Dec 21, 2009 | 06:53 AM
CenterIsl's Avatar
CenterIsl
Ditto on the sunroof - all the way open and hold down a few secs, and all the way closed and hold a few secs (I think). Otherwise it doesn't know where "open" and "closed" are. You'll also have to reset your navigation region.
Old Dec 22, 2009 | 05:18 AM
jbyham's Avatar
jbyham
THANK YOU! Great help on this one. You were right on with the fix. Thank you.
Old Sep 8, 2012 | 12:01 AM
peteharvey's Avatar
peteharvey
Does anyone know why this phenomenon occurs???
Old Sep 8, 2012 | 03:32 AM
ALAN553's Avatar
ALAN553
It's a computer thing so phenomenon are a fact of life?
Old Sep 8, 2012 | 04:48 AM
RickC5's Avatar
RickC5
Ha ha! Boy, isn't THAT the truth!
Old Sep 8, 2012 | 08:48 AM
Taco_Kid's Avatar
Taco_Kid
to get you to call the dealer to make an appointment to come in. they wont charge for the fix, but they have you at the dealer, etc.
Old Jul 13, 2013 | 06:51 PM
jkgsooner's Avatar
jkgsooner
Default Wow. Thanx.
I was trying to figure out what it might cost to order a new master window control set, and this advise worked like a charm. THANX again!
jkg
Old Aug 9, 2013 | 02:42 PM
rickvdj's Avatar
rickvdj
Confirmed!
This method did the trick. I did the following:
1. Pressed the START button twice to put the car in the on the ON position (radio on)
2. Went to passenger side pressed and HELD the control button till the window was 100% down, then pressed and HELD till window is 100% up
3. Went back to Driver Master Control and tested.
4. Repeated steps 2 & 3 for rear windows individually
Good luck peeps!
Old Aug 12, 2013 | 09:01 PM
Enzoxyz's Avatar
Enzoxyz
Such a silly steps. Good thing I won't be replacing the battery soon.
