2007 gs350 daytime running lights/high beam bulb
Old 05-16-12, 08:37 PM
michaelmay
michaelmay's Avatar
Default 2007 gs350 daytime running lights/high beam bulb
Hello,
I do not really like the yellowish glow of the stock bulbs so I was wondering if there was any alternative to get them white like the headlights. I'd prefer not to do an HID conversion but if there is a bulb that will give me the same effect, could you please tell me?
I have also looked through the threads and I could not seem to find out how to install the bulbs once I purchase them. Please assist!
Thanks!
Old 05-16-12, 08:54 PM
bigblack06
bigblack06's Avatar
You sure you looked, I only say this cause it has been discussed many times. Your best choice would be LED's here you go! https://www.clublexus.com/forums/gs-...t-194-led.html
Old 05-16-12, 08:58 PM
michaelmay
michaelmay's Avatar
I've already seen that and it has helped me replace my parking lights. I am looking on how to replace the high beam bulb which is bulb size 9005. the bulb in the link you gave me is bulb size 2825
Old 05-17-12, 01:14 PM
j0emama
j0emama's Avatar
Just to be sure you are aware by switching your DRL/High beam to LED, you'll be eliminating your High Beams. I guess you don't find them useful, why not...?
Old 05-17-12, 01:38 PM
ITWORKS
ITWORKS's Avatar
OK I just did this LED DRL install. I love it with the LED's. It looks really classy and no one is getting blinded during dusk hours. You loose the High beams but I didn't care either. Last week there was a whole back and forth, a threadjacking and everything....hahaha. The lights toggle and it seems to get peoples attention. Here's how mine look with the 64 LED version. VERY SIMPLE BULB SWAP. During the day it's softer.
https://www.clublexus.com/forums/gs-...gs-in-mia.html
In this thread he's got good pictures of how to remove the covers under the hood to access the lights. Once you reach the socket , turn it counter clockwise and pull it out. It's a little tricky to get your hand in there but it is possible.
https://www.clublexus.com/forums/gs-...-hi-beams.html
OH.... and you are going to need " warning cancellers " or the lights will flicker. They go inline with the lights. <----- no biggie.
Hope this helps. Good luck,
Old 05-17-12, 03:42 PM
michaelmay
michaelmay's Avatar
Thanks!
So my options are either to get an HID conversion kit to keep my high beams OR LED plug and play with cancellers and lose my high beams?
Old 05-17-12, 03:46 PM
ITWORKS
ITWORKS's Avatar
Yeah. thats pretty much it.I personally like the LEDs
Old 05-17-12, 03:49 PM
XxGoKoUxX
Forum Moderator
XxGoKoUxX's Avatar
Theres white bulbs out there also.... Dont mistake that, theyre just not as bright as regular highbeams when needed.... Go on ebay and pick your bulb color to your satisfaction (make sure theyre within wattage spec and also id opt for blue because the bulbs look blue but mostly output white)
Old 05-17-12, 05:30 PM
07LXgs350
07LXgs350's Avatar
yah but if its running at half power its going to look yellowish, not much different than stock.
Old 05-17-12, 06:16 PM
2008GSh
2008GSh's Avatar
If you want your cake and eat it too... if you want DLR that work AND highbeams that are there when you need them.. And you don't want LEDs that are too dim on High Beam or HIDs that are (IMO) too bright on DLR then buy a pair of "blue" tint 9005 bulbs on ebay for <$5 and call it a day.
All of the other options have limitations...
For fhe fog lights I like the HID system that XxGoKo installed since these are either on or off and aren't need to "flash to pass" or anything else.
Old 05-17-12, 07:01 PM
michaelmay
michaelmay's Avatar
which ones would you recommend? I have the stock headlights and I would like the DRL to kinda match them in color but be equally bright or slightly less bright.
Old 05-17-12, 08:24 PM
j0emama
j0emama's Avatar
There are no "white" halogen lights, they are all yellowish. I've tried the best Philips (Crystal Vision Ultra) and Sylvania (SilverStar) and barely any difference for the $50+ they cost, not worth it. What most people have done is just had the dealer turn off they're DRLs all together.
If you go the LED route and give up your high beams, the OEM headlight color is 4300k, so the closest LED you can get to match would be 5000k, which is pure white.
**Note: When you headlights come on DRLs turn off and PARKING lights engage. Those can easily (and should be) changed out to LEDS.
Old 05-17-12, 08:34 PM
michaelmay
michaelmay's Avatar
Yeah im thinking im just going to have my headlights on all the time and Ive already swapped the parking lights for LEDS. Its got kind of a bluish tint because of the housing. Can you recommend any LEDS that would show white?
Old 05-18-12, 07:20 AM
j0emama
j0emama's Avatar
Any type of LED will do the job, if you want pure white go with 5000k color. That's about as WHITE/CLEAR as it gets. A lot of people (including myself) use 6000k which has a "slight" blueish tint, but looks good.
If you want quality def. purchase them at: http://www.v-leds.com/ Go on their facebook page and look for coupon/discount codes.
Old 05-18-12, 04:11 PM
2008GSh
2008GSh's Avatar
Lots of companies sell blue/white tinted Halogens, if you can't find them, then you aren't looking. Yes ALL of the OEM ones are yellow... We are all considering aftermarket options here.
Quick Reply: 2007 gs350 daytime running lights/high beam bulb
