Low washer fluid warning
Old 06-27-10, 05:48 PM
mark98ls40
mark98ls40's Avatar
Default Low washer fluid warning
Still on after filling fluid. It came on during a rain storm.
Any one know if its a sensor in the washer fluid tank?
Old 06-27-10, 06:52 PM
tcbted
tcbted's Avatar
I let the washer fluid go dry on my 2000 LS.
When I refilled, the warning stayed on.
I took the easy route .... poked at the stuck float with a coat hanger.
Magically, it free'd up and the warning turned off.
Easy fix, took a minute or two.
Old 07-02-10, 12:07 PM
mark98ls40
mark98ls40's Avatar
Tried the hanger trick with no luck.
Is there a float in there? I must have missed it.
I thought it might be some kind of sensor.
Old 07-02-10, 12:33 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
you can just unplug the sensor. its a plug at the bottom front of the washer bottle.
Old 07-02-10, 04:13 PM
mark98ls40
mark98ls40's Avatar
Thanks, I saw the plug & will unplug it. I thought if you unplugged, it would stay on all the time so thanks for the advice.
Old 11-19-10, 08:27 PM
TONY1022
TONY1022's Avatar
HEY MARK.
was your problem solved by just unplugging the sensor? I have the same with my 98 ls 400 and it's driving me nuts.
TONY
Old 12-19-10, 04:41 PM
ktranne
ktranne's Avatar
just did this couple min. ago. It works. No more warning light.
Old 12-20-10, 09:13 AM
98LSUK
98LSUK's Avatar
Hi
The above will switch the light off but it will also disable a useful feature of the car.
The actual fix is not hard at all - To fix you need to remove the float switch which is accessible from under the washer bottle - it is held in place by a rubber gromet - to remove just wriggle it out and it will come out - you then need to dry it out on a heater ( i left mine on the heater for a week and afterwards gave it a coat of varnish to make it water proof before putting it back in)and then pop it back in again - thats it
The reason why the light come on is becuase the polystyrene float absorbs water over time and gets heavy and sinks tripping the switch and causing the washer fluid light to stay lit
hope this helps
miq
waqas300
12-04-19 07:58 PM
Dx3
09-05-16 07:40 PM
Greg5OH
11-21-14 04:29 PM
McSwine
04-27-10 01:42 PM
99LS400BLK
01-16-07 12:32 PM
Quick Reply: Low washer fluid warning
