Steering controls for radio and nav stopped working but not phone -- any ideas?
Old 04-12-10, 09:34 AM
JohnnyCake
JohnnyCake's Avatar
Default Steering controls for radio and nav stopped working but not phone -- any ideas?
Suddenly, the steering wheel controls for the radio/cd/etc stopped working -- no MODE change nor UP/DOWN volume. Likewise the control on the back of the wheel to summon the NAV voice control does not work. However, the phone control on the back of the steering wheel DOES work.
Does this suggest anything (other than a trip to the dealer)?
Old 04-12-10, 04:57 PM
Gfather
Gfather's Avatar
Default Audio Controls
Sounds like your "Spiral Cable" is defective. I had the same issues which were resolved once replaced by the dealer. The problem, accordig to the dealer was an open circuit.
2006 Lexus SC430 - Smoky Mica Granite with saddle interior..
Old 04-12-10, 05:45 PM
JohnnyCake
JohnnyCake's Avatar
If you don't mind me asking, how much did that repair cost?
Old 05-17-10, 10:02 PM
Leisurelar
Leisurelar's Avatar
I would be interested to know the outcome as I have the same problem. Maybe it is the color.
I have a 2006 Smoky Granite Mica with Black interior. lol
Old 05-18-10, 06:06 PM
JohnnyCake
JohnnyCake's Avatar
If you get yours fixed, PLEASE post the diagnosis.
Old 05-19-10, 09:39 AM
Leisurelar
Leisurelar's Avatar
I think it is the spiral cable as I can turn the wheel to different spots and it will work. If or when I get it fixed I will post results, unfortunately it will not be warranty, Jan was my time limit, of course.
Old 05-26-10, 08:08 AM
Habious
Habious's Avatar
Super-big kudos to Gfather who nailed this problem right out of the gate!
Also wanted to make sure this thread got updated so, in the future, when someone comes across the same problem, the solution will be right there with it.
Turns out it WAS the spiral cable all along...and JohnnyCake is no longer crying himself to sleep...or wandering around the Mercedes dealership, looking longingly at the convertibles parked there.
Old 05-26-10, 08:18 AM
JohnnyCake
JohnnyCake's Avatar
I definitely agree that updating threads is important. Related thread is at:
Don't let the dealer tell you that LuxLink caused this problem.
Old 12-27-10, 12:54 PM
nwcn98
nwcn98's Avatar
I'm late to the game, but my car is an 06 in the same colors...and the same issue
Old 12-27-10, 04:31 PM
scdroptop
scdroptop's Avatar
Look further down on the threads...we just talked about this yesterday or day before....I just had mine replaced under warranty at Sewell $480 or so. Sorry to hear...not a big deal...hopefully you have warranty.
Old 04-21-12, 01:44 PM
Leisurelar
Leisurelar's Avatar
Took a while but I just replaced my spiral cable sub assembly updated part # 8430651030 for a 2006 SC 430.
Part came frome Sewell price was 207.27 took about 40 min to replace and solved the problem.
Old 04-21-12, 03:52 PM
Harold57
Harold57's Avatar
Did you do it yourself or have it done?
Old 04-22-12, 08:46 PM
Leisurelar
Leisurelar's Avatar
I did it myself quite straight forward. Remove neg bat cable for air bag, I did not do this and had no issues, remove small round plug on right side back of steering wheel, push pin lock in on radio control buttons left side of wheel and lift off cover, remove 2 small phillips screws from radio controls let hang down, remove the #30 torx screws from either side of wheel, screws must come out completely, lift off and unplug air bag, Loosen steering wheel with a 19mm socket do not take nut right off yet, make sure wheel is centered and use your knees under the wheel and hands on top to work the wheel off of the splines, when wheel is loose remove the nut the rest of the way. Unplug remaining wires and remove wheel, take three phillips screws out of the bottom steering column cover and move down out of the way, undo the rest of the plugs, remove xtra plug box from spiral cable,(just snaps in) remove 2 small springs from old cable these are the horn return springs, plug in and reinstall new spiral cable and break off orange indexing tab. Reassemble in reverse.
benwah (11-13-22)
JohnnyCake
09-27-14 10:17 AM
Mcbmatt
10-29-12 09:10 PM
Ducati11
04-14-07 05:25 AM
05-02-05 03:20 AM
sexylexysc430
03-17-05 11:29 PM
Quick Reply: Steering controls for radio and nav stopped working but not phone -- any ideas?
