Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
Headlight cleaner?
Old May 13, 2001 | 05:10 PM
anthracitetarga's Avatar
anthracitetarga
I remember seeing a post somewhere about this stuff (i think from Meguiars) that cleans the plastic on ur headlights and makes them look brand new. Anyone know where this post is or what i am talking about???
I would like to just clean the outside of the headlights b/c it sounds like it is a lot of trouble to clean the inside and then reseal them. Also, does anyone know how to take out the high beams (center oval lights)?
Old May 13, 2001 | 08:29 PM
The Ikon's Avatar
The Ikon
Exclamation
MyLexus,
It was Plexi Polish by .... uh I forgot, it's in the garage... please don't make me get it now. I got it from Auotzone for $3.99 it is recommended for plexig glass, convertible back glass, any plastic type lens. I also use it for my rear lens, corner lights, high beam covers, etc..
I'll edit this reply tomorrow once I go and get the bottle... Just for you.
Old May 14, 2001 | 08:49 AM
Keith13b's Avatar
Keith13b
25 Year Member
Heres what you need-
Meguiar's Mirror Glaze Clear Plastic Cleaner #17 (M-1708)
and
Meguiar's Mirror Glaze Clear Plastic Polish #10 (M-1008)
They come in 8 oz bottles.
This stuff works like gold. I was this close to dropping down a few bills to get new lenses for my headlights and high beams. Thank God I didn't. I didn't even have to remove them and pop them in the oven like a frozen pizza as stated in the Supra Forum. I left those sum'b!tches right on the car and hit them with a buffer. Less than 10 minutes later, they looked crystal clear and mine were pretty bad! Now they look BRAND F'N NEW!!!!! W/O a buffer it might take a little elbow grease, but who cares. The end result is simply soooooo worth it. Good luck.
Keith
Old May 14, 2001 | 07:12 PM
Brian S's Avatar
Brian S
I've got a three inch scratch on one of my GS headlights. I think some jerk had fun with his keys. Would this stuff get it out?
Thanks,
Brian
Old May 14, 2001 | 07:44 PM
RealMarty's Avatar
RealMarty
Lightbulb Steel Wool
Thanks,
Brian
I haven't tried this, but I've read that you can use very fine steel wool (like 0000 or more zeros) to take down the scratch -- then use the Meguiar's.
You should be able to get the steel wool at a building supply or an auto parts or glass store.
It may not totally remove the scratch, but it can make it much less noticeable.
Old May 14, 2001 | 08:14 PM
Brian S's Avatar
Brian S
Hmmmm, steel wool?? :eek: I'd think that might put more, fine, scatches in the plexi.
Brian
Old May 14, 2001 | 08:26 PM
RealMarty's Avatar
RealMarty
That's why it has to be very fine steel wool. This is much finer than the steel wool used in the kitchen. Think of it more as a polishing tool. If you used it on dull metal it would shine it up.
It will leave small fine scratches, but it will take out larger ones. Then use the polish to remove the small scratches from the steel wool.
Old May 14, 2001 | 08:46 PM
Brian S's Avatar
Brian S
Okay, I'll keep that in mind when I get back to the mainland next month. I really want to get rid of that scratch.
Thanks,
Brian
Old May 15, 2001 | 03:19 AM
sc400nos
Guest
Posts: n/a
Ok, think about it, a scratch is a removal of a material. You cannot take away something that has been taken away. The only hope you have is to hide it, crappy, or buy a new headlight.
Old May 15, 2001 | 06:09 AM
RealMarty's Avatar
RealMarty
sc400nos,
You're right. If I knew of a material that could fill the scratch and make the repair invisable I'd jump on that in a second. If someone knows of such a material and how to apply it I'd love to learn about it. It would be the perfect solution. (I've heard you can use clear epoxy or Krazy Glue.)
If the material around the scratch is thick enough, you can lower the surrounding material to make the scratch less noticable...and virtually hide it except for a close inspection.
Also, if the scratch is not too deep you can bring the surrounding material down to the lowest part of the scratch and "disappear" it.
Clearly, the best repair is to replace it. But, this technique may salvage the light and save $ and time.
(BTW, I've seen classic car demonstrations where they use the fine steel wool on taillights, etc to get off the grunge and powdering that happens over time. They say you should put a coat of wax on the plastic after using the steel wool to keep the shine.)
Old May 15, 2001 | 01:27 PM
Brian S's Avatar
Brian S
I'm curious how the Plexi-Scratch remover works. I'm thinking it's some type of acidy stuff that eats away and blends the scratches into the light. Is the stuff permenant, or is it like a wax that must be continually applied?
Thanks,
Brian
Old May 15, 2001 | 07:09 PM
GS3-Kid858's Avatar
GS3-Kid858
where do u guys buy the pexi-glass cleaner for $3.99?? i just bought it for $6.99 help please
1992 SC300
Aug 2, 2007 11:28 AM
retrodrive
Apr 27, 2004 10:17 AM
dad&4qtz
Lighting
Oct 6, 2003 11:23 AM
Billbosh
Nov 4, 2002 11:52 PM
MrX
Oct 18, 2002 12:59 PM
