97 SC300 W/ Traction Control?
Old Feb 24, 2010 | 01:08 PM
2BENVD's Avatar
2BENVD
Default 97 SC300 W/ Traction Control?
just curious, do i have traction control, i remember my cousins sc400 having a traction control switch by his automatic shifter but mine doesnt, so do i have it and where? Simple answer would be nice
Old Feb 24, 2010 | 01:09 PM
MarcusMIA's Avatar
MarcusMIA
I'm pretty sure they took of traction control after a certain year. Mines is a 1996 and it does not have traction control...
In fact, if I remember correctly (hopefully) I remember the trac fuse being empty when I checked the fuses last time.
Old Feb 24, 2010 | 01:25 PM
RedPhoenix's Avatar
RedPhoenix
look at your throttle body. 2 TPS sensors = TRAC, 1 TPS sensor = NO TRAC.
Old Feb 24, 2010 | 01:38 PM
BigGreen's Avatar
BigGreen
97's came with trac control but its located by the shifter and seat warmers if u got those. If its not there then no trac. Dont worry trac control is for non drivers!
Old Feb 24, 2010 | 01:57 PM
2BENVD's Avatar
2BENVD
thanks guy, just wanted to clear that up
Old Feb 24, 2010 | 10:13 PM
SpiderN9NE's Avatar
SpiderN9NE
Post Mines different
I have a 99 sc300 and its not on the shifter near the warmers. Mine is down where the trunk and gas door buttonsn are. Not saying you guys are wrong because on my 93 thats where it was, near the shifter. Im just pointing out that its different on my new one but i cant tell you when it changed positions.
Old Nov 4, 2010 | 06:53 PM
trini9227's Avatar
trini9227
so if you get a trac fuse and put it in there will it work, if it is not in there already?
Old Nov 4, 2010 | 07:08 PM
horent135's Avatar
horent135
Trac control or not, it all depends where the car was originally purchased. Ex. if car brought in Florida, there no trac control because it is not needed in that state.
Old Nov 4, 2010 | 07:51 PM
nfordhk's Avatar
nfordhk
I thought the 97 came with trac control just didnt have the button for it and you have to do some damn peddle dance to turn it off?
Old Nov 4, 2010 | 08:24 PM
TexasSC300's Avatar
TexasSC300
I know my 98 SC300 has it only its a longish switch down on the lower left side of the dash. You cant see it because its kinda under the steering wheel and to the left. above the trunk and gas lid release. Also, when you are turning on your car you should see the Trac-control light...It will flash when it is being used. I tested it out the other day while I attemped to fishtail on a rainy day...IT just flashes on and off intermittenly.
The 97 SC300 should have it.
Old Nov 4, 2010 | 08:29 PM
aka paco's Avatar
aka paco
my 97 sc300 has it, it's the button above the shifter to the right, the seat warmers are both on the upper left side, and ect power is on the bottom left
Old Mar 9, 2011 | 10:16 PM
1998sc300's Avatar
1998sc300
i have a 98 sc300 and it has traction control. (it sounds silly) but it wont let me do a burn out. i will push the brake pedal to the floor and press the gas and the tires start to spin but then the TC light comes on in the dash and the rpm's go back down and the tires stop spinning. how do i override TC all together?
Old Mar 9, 2011 | 10:48 PM
ScBouncE's Avatar
ScBouncE
Trac control was actually an option on SC's like alot of other features. If you had the winter package, than the car came equipped with TRAC and heated seats. otherwise it didnt have it. All SC's came with an option for trac i believe even till 2000
Old Mar 9, 2011 | 10:53 PM
1998sc300's Avatar
1998sc300
yeah i have heated seats and theres a snow trac option on the button but even if i turn it off all together the light still comes on when i break the traction on my wheels and it corrects the slide
Old Jun 6, 2011 | 01:12 PM
Midengtoy's Avatar
Midengtoy
I have a '97 SC400 with no Trac but it seems like it has Trac. I checked and no Trac switch and no Trac relay but when I drive and I floor it it seems like trac kicks in because it wont let the rear wheels spin. It feels just like my old LS400 when the track kicked in. Any ideas what is causing that or are the SC400's just slow and can't spin the wheels?
Markmorbid
Oct 7, 2017 09:41 AM
djeffers
Aug 17, 2017 08:09 AM
JDM FINEST
Feb 13, 2011 11:00 PM
trini9227
Nov 5, 2010 09:03 PM
Dima87
Jul 31, 2005 12:10 PM
