View Poll Results: Ever use the AUX/MP3 input jack?
Yes!
312
75.00%
No!
37
8.89%
Why bother ? 6 disc changer that plays mp3 is good enough !
64
15.38%
MP3? WTH is that?
0.72%
Voters: 416. You may not vote on this poll
AUX/MP3 input?
Old May 15, 2008 | 01:15 PM
  #106
Brian231's Avatar
Brian231
Not sure if anyone posted this, but the Lexus Perfomance Driving Academy gave an IPOD cable as a part of the gift bag. It was a reallt nice gesture even though I bought one a year back. Just a heads up for all those attending.
Old May 16, 2008 | 06:28 AM
  #107
AB_'s Avatar
AB_
I use it for an iPod every once in a while.
Old May 16, 2008 | 08:18 AM
  #108
APBT4Me's Avatar
APBT4Me
i have the vaistech kit so i have no reason to use the AUX. its much nicer this way, charge and play w/ one cord that is hidden out of sight in the glovebox and control through the OEM steroe controls. who could ask for more...
Old Jun 29, 2008 | 10:00 AM
  #109
ELL Y's Avatar
ELL Y
I always use the aux.
slightly inconvenient cause of location, but the wire hides under the console even when it's closed so it's not too bad.
and i have a rubber casing on my ipod so it holds it in place
Old Jun 29, 2008 | 11:20 PM
  #110
ISWillie's Avatar
ISWillie
Originally Posted by Bichon
Using it to connect my iPod. I'm using a cable that goes from the line level output on the iPod's dock connector to the car's aux jack, which gives better sound quality than using the iPod's headphone jack.
+1
... although, I did have to go to the dealer and have the AUX TSB performed because of engine noise coming through the system... even though I am using the Monster Cable unit. No problems since that fix, and I use my iPod daily in that port.
Old Jul 3, 2008 | 09:03 PM
  #111
Sytfu_IS's Avatar
Sytfu_IS
Originally Posted by stvn
i just used a 3.5mm cable to connect the ipod to the aux. the sound quality is so-so and some of the speakers don't work for the ML! does anyone else with the ML have this problem?
It happens to me sometimes, I have to move the cable around to make it all work =/
Old Jul 3, 2008 | 09:21 PM
  #112
ISWillie's Avatar
ISWillie
Not just that, but if you are using the headphone jack for your source, you are going to have terrible sound. As Bichon said, it is important to utilize the line level output at the bottom of the iPod for maximum quality.
Old Oct 24, 2009 | 05:26 AM
  #113
ijulmimi's Avatar
ijulmimi
Originally Posted by SParker1tx
iPhone + Aux input works nicely
Which aux cable do you use? I've been searching informations on how to play my iphone through the aux but still can't find it.
Old Oct 24, 2009 | 08:14 AM
  #114
Kurtz's Avatar
Kurtz
I use the Belkin kit myself, plays through aux and charges
Doesn't charge the newest gen stuff (like iphone 3G and newer) but you can get an adapter to do so if you need it and plays music regardless
Old Oct 24, 2009 | 04:34 PM
  #115
ijulmimi's Avatar
ijulmimi
thanks Kurtz. You're the man!
Old Nov 7, 2009 | 09:29 AM
  #116
Omega99's Avatar
Omega99
Obviously since no one else has said it my case must be an isolated event but, mine only plays in mono through the front speakers. Guess I'll bring it up next time I take it to the dealer. Which will be soon since my driver side controls for both passenger side windows stopped working after my battery died and I had to change it out.
Old Nov 7, 2009 | 09:36 AM
  #117
Kurtz's Avatar
Kurtz
You need to reset the windows...takes 2 minutes and is described in your owners manual.
The mono issue is probably the cable you're using.
Old Nov 7, 2009 | 04:35 PM
  #118
kdii02's Avatar
kdii02
Originally Posted by Dj_AmtraX
I actually like the location of the AUX jack. I can control and hide my iPod at ease. The volume on steering works as well. For a $20.00 cable, it sounds GREAT. Why spend $200+ to control your iPod on the radio.
Where did your get this cable?
Old Nov 17, 2009 | 02:30 PM
  #119
fredw1's Avatar
fredw1
I found this one at Amazon:http://www.amazon.com/Cables-Go-3550...8496831&sr=8-1
Old Dec 3, 2009 | 10:18 PM
  #120
2007ISDRVR's Avatar
2007ISDRVR
I'm getting alot of humming and "ground noise" from my iPod when I use the aux-in. Any ideas?
