Removing Door Panel for 2004 LS430 to install Actuator...
Old Oct 31, 2009 | 11:44 AM
Moogy's Avatar
Moogy
Question Removing Door Panel for 2004 LS430 to install Actuator...
I've got my new Actuator, and looking at it, seems pretty simple to install. The only issue is I can't find any instructions on removing the door panel (front drivers side).
Has anyone here removed the door panel and installed a replacement actuator?
Any references or instructions would be appreciated.
Old Nov 1, 2009 | 11:24 AM
brio_ls's Avatar
brio_ls
Here you go
http://bahamutcars.free.fr/workshop/.../m_75_0017.pdf
Old Nov 1, 2009 | 02:58 PM
Moogy's Avatar
Moogy
Awesome PDF - thanks!
But holy crap - I did my brakes myself, and it was cake. This is a major PITA. I've taken off the door panel, but I don't know exactly how to manage the lock assembly separate from the actuator. I think I'm going to pass this one to a Mechanic. It's by no means easy at all.
Old Nov 1, 2009 | 03:41 PM
REV-01's Avatar
REV-01
i look at the link. you can change the door lock motor without taking out the regulator. just make sure you pop out the keyhole cylinder first. i did beangrower's one i think i charge him only 60 bux to do one front and one rear.
Old Nov 2, 2009 | 10:38 PM
Vpanin's Avatar
Vpanin
Originally Posted by brio_ls
Where can you get these PDFs????? on other things
Old Nov 4, 2009 | 01:19 PM
toantran99's Avatar
toantran99
Moogy, how's the installation going?
Old Sep 14, 2010 | 10:41 PM
Cruisinthr's Avatar
Cruisinthr
Worked like a charm - thanks for the link. I had a body shop replace a broken passenger window, but the damn thing kept reversing half-way down everytime it got to the top. It took a lot of work to take the thing apart - shame on Lexus engineers for making it so difficult - but following the instructions on the PDFs was a big help.
A footnote to the re-setting of the anti-crush feature on the window. Someone tagged on this comment to the Lexus instructions and I thought I'd share it with whomever wants to use it. It worked for me:
The window motor needs to be clocked, most glass installers are clueless, so never do. To fix it, the motor must be removed from the regulator, then the switch plugged back in. Hit the down button, and let the motor turn until it stops, then bump it back up until the gear has made six full turns. From there, just reinstall the window motor, and you'll be good to go
Cheers,
Kevin
ReyRey305
Mar 20, 2021 06:48 PM
wbcor
Maintenance
May 25, 2019 11:49 AM
tarheel49
Dec 24, 2018 04:05 AM
corkycal
Oct 29, 2010 02:20 PM
