300 still the best RX model!
Old Mar 27, 2009 | 04:39 PM
scargo's Avatar
scargo
Default 300 still the best RX model!
OK, this is biased because we're in NYC. But our 2003 RX 300 is SO easy to park -- because it's ONLY 180" long -- and it is SO roomy inside, has great visibility and has SO MUCH cargo space. What an amazing design! The newer RX models are too big for parking easily in Manhattan, the visibility is not good (hence one must have a rear-view camera, like it or not), and the cargo space has actually shrunk a little.
We've been trying to find a new compact SUV that has all the wonderful RX300 characteristics, but none does. RAV4 is the closest, but that's not acceptable. Why can't Lexus replicate the RX300 design??
Old Mar 27, 2009 | 05:31 PM
bob2200's Avatar
bob2200
I agree with you that RX300 is the best of the RX series. The only downside is the wide turning radius. I hated the center storage "pit" in the RX330 (instead of drawers), and the 2010 model doesn't even have an open area between the front seat leg areas.
I haven't really been looking, but I think the current Honda CR-V might come the closest to the RX300, particularly in length, weight, and layout.
Old Mar 27, 2009 | 07:59 PM
AlexusAnja's Avatar
AlexusAnja
Since you're talking Toyota and Honda... no consideration for the Highlander?
As for design, I think the 1st GEN is still the best CUV ever. Redefined the market, for good or bad. The RX300 seems like they put a lot of thought into it, because they wanted to get it right the first time, but then the 330/350 and 2010 350 it's almost been change for change to make it look different... not better, just different.
The 2010 350 video monitor, you're telling me that couldn't be designed to look better integrated into the headrest? Looks like an afterthought of "oops, we forgot to design the monitor..."
On paper, the 330/350 was NOT smaller than the 300 interior, but it felt and does have less usable space in terms of interior full width and height etc.
There have been no improvements that were outstanding on the 330/350 to make me switch and the 2010 has made me consider jumping makes if my 300 fails before 2015 for 2016 model year.
Old Mar 27, 2009 | 08:08 PM
RX469's Avatar
RX469
I agree with all the above..........except for the afterthought of a decent cupholder. It's such an issue for me. sigh.
Old Mar 27, 2009 | 08:28 PM
cliffud's Avatar
cliffud
Former Vendor
i was under the impression that the 300 had sludge issues? no?
Old Mar 28, 2009 | 04:45 AM
bob2200's Avatar
bob2200
And you could have added transmission failure issues.
I think there is consensus that sludge isn't an issue if you change your engine oil every 3-4,000 miles with a high quality oil. Also, the sludge seems to effect the 1999-2000 models the most.
There is some indication that doing a transmission fluid drain-and-refill every 15,000 may reduce transmission failures to a low rate.
Old Mar 28, 2009 | 06:33 AM
mikey00's Avatar
mikey00
I have the itch to replace my 2001 RX SS but so far have found all the possible replacements unacceptable. If for some reason I had to do it today, I think the CR-V would be my pick. Whats with all the new designs and the lack of visibility so you now require a back up camera?
Come on Lexus, take the RAV4 get rid of the ugly tire on back, fix the hatch so it opens the right way, Lexus it up a bit and throw a Lexus emblem on it
Old Mar 30, 2009 | 10:26 AM
cduluk's Avatar
cduluk
If lexus put the rx300 back into production, but fixed the tranny, the turning radius, and added new features such as the push start and HUD, i would buy it in a heartbeat.
It is so much better looking than the newer models. People always tell me that it looks brand new. It's not outdated at all...
Old Mar 30, 2009 | 10:56 AM
jimmouse's Avatar
jimmouse
I have 01 AWD ~209k miles. So far no eng or tranny issues. And I can do parallel in NYC no issues due to the great visibility. Thus no issue with turning radius.
Old Mar 30, 2009 | 11:58 AM
salimshah's Avatar
salimshah
25 Year Member
My only design complaint has been the encroachment inside the rear trunk from the rear wheel suspension. The alternative would have been leaf-springs and they would have impacted the ride. Cant have them all.
Salim
truenorth
Jan 22, 2016 06:03 AM
Dadikins
21
Nov 4, 2010 12:29 PM
archangels
Mar 17, 2008 04:44 PM
pierce
13
Dec 2, 2002 10:19 PM
Yeowww
Dec 1, 2002 12:22 PM
