Lexus GS Recall on 2006 2007 models Just annouced
Old Jan 16, 2009 | 02:32 PM
cbrfreak's Avatar
cbrfreak
Default Lexus GS Recall on 2006 2007 models Just annouced
Lexus announced thru channels today that there is a campaign(recall) on 06-07-GS 300 and 350"s
They will be replacing the Fuel Rails for the fuel injection, the Electronic steering racks, and rear brake caliper bolts.
[B]If you are in the NY area call the guys at Rallye Lexus 516-676-8686 if you need help. They always help me and are the guys that do the car show and are active on this site.
Special Service Campaigns (SSC)
SSC 9LA Certain 2006 2007 GS, 2006 2008 IS and 2007 2008 LS Vehicles Fuel Delivery Pipe Replacement
SSC 9LB Certain 2006 2007 GS and IS Vehicles Rear Brake Caliper Inspection
SSC 9LC Certain2006 2007 GS, IS and RX 400h Vehicles Electric Power Steering Link (EPS) Assembly Replacement
******URGENT******
On January 16, 2009, Toyota filed a Defect Information Report (DIR) with the National Highway Traffic Safety Administration (NHTSA) regarding certain 2006 2007 GS 300/350, 2006 2008 IS 250/350 and 2007 2008 LS 460/460L vehicles. The involved vehicles are equipped with aluminum fuel delivery pipes (fuel rails). Lexus has determined that ethanol fuels with low moisture content will corrode the internal surface of the fuel rails. As this condition progresses the engine malfunction light (MIL) may illuminate. Over time, the corrosion will create a pinhole resulting in fuel leakage. SSC 9LA will be launched to replace the Fuel Delivery Pipes in the affected vehicles.
There are approximately 43,700 GS 300 (24,500 2WD, 19,200 AWD), 23,700 GS 350 (14,000 2WD, 9,700 AWD), 85,800 IS 250 (54,000 2WD, 31,800 AWD), 24,900 IS 350, and 36,400 LS 460 (25,500 LS 460, 10,900 LS 460L) vehicles involved in the U.S.
Additionally, Lexus is launching two other SSCs.
9LB Certain 2006 2007 model GS and IS vehicles to inspect rear brake calipers. On certain Lexus vehicles, the slide pin in the rear brake calipers may not operate smoothly. If the vehicle continues to be operated under these conditions, the brake pads may make noise.
9LC Certain 2007 GS 450h, 2006 2007 GS, IS and RX 400h vehicles to replace the electric power steering link (EPS) assembly. Certain vehicles may experience a noticeable gradual increase in the steering effort necessary at low speeds when turning the steering wheel to the complete left or right position. This condition may be most perceptible when parking the vehicle.
A dealer package including vital information and reimbursement procedures will be sent to dealers (to the attention of the service manager) today.
Lexus will inform owners of the involved vehicles with a Special Service Campaign notification letter sent via first class mail beginning in late January 2009.
All customer inquires should be directed to the Lexus Customer Assistance Center at 1-800-255-3987.
If you are a dealership associate and have any questions, please contact your District Service and Parts Manager.
The following Q&As has been provided for your reference.
Click here to see Combined Q&A for DD Message.pdf
Cancel
Print
[/B]
Old Jan 16, 2009 | 02:50 PM
maying856's Avatar
maying856
Ooooooooooo
Old Jan 16, 2009 | 02:57 PM
ProfesrLEX's Avatar
ProfesrLEX
ouch. i feel sorry for lexus
Old Jan 16, 2009 | 04:23 PM
dandd2's Avatar
dandd2
holy ****
i knew something was wrong with my rear brake caliper
when i was getting my brake pads changed out the mechanic stated that the bolt on the brake was missing.
since then last time i got my oil changed i had complaints because of rattling coming from the rear of my car.
the mechanic took a look and said the rear caliper was loose due to the bolt falling out again.
i definitely need to take my car to lexus
Old Jan 16, 2009 | 04:35 PM
Stormforge's Avatar
Stormforge
executive matchup
interesting...so '08 GS not affected?
Old Jan 16, 2009 | 04:49 PM
djentee's Avatar
djentee
oh well, i know that they will get this issue fixed and $$$ is not an issue with Toyota. i'm glad that Toyota takes action once they determine a factory defect on their vehicles.
Old Jan 16, 2009 | 05:10 PM
dunnojack's Avatar
dunnojack
that's good. i don't mind fixing as long as they don't take apart my dashboard.
i will wait a few months so you guinea pigs can go first.
Old Jan 16, 2009 | 05:21 PM
djentee's Avatar
djentee
^^^ they might run out of parts.
Old Jan 16, 2009 | 05:27 PM
ivanz's Avatar
ivanz
Any info about this in Canada? I don't have any problem with my 2007 GS 350, which was built in 03/07...except the dash rattle. Nothing under campaign in Club Lexus either.
Old Jan 16, 2009 | 05:34 PM
vietdeluxx's Avatar
vietdeluxx
Hmm...interesting. Thanks for the info
Old Jan 16, 2009 | 05:42 PM
ekc's Avatar
ekc
So when can we start making appointments to get this fixed? Like today?
Old Jan 16, 2009 | 07:52 PM
steviej's Avatar
steviej
Interesting, the fuel rail pipe replacement was actually first announced in November of 2007. Already had mine done. Will check on the other two, though.
steviej
Old Jan 16, 2009 | 08:33 PM
I8ABMR's Avatar
I8ABMR
Thanks a lot man. I appreciate the info. I will not this and call my service guy
Old Jan 16, 2009 | 09:11 PM
tod071's Avatar
tod071
Thanks for the info
Old Jan 16, 2009 | 11:51 PM
dunnojack's Avatar
dunnojack
no they won't
worst case is you'll have to wait a few weeks.
