Replacement Battery - Tough to Find :(
Old Jul 27, 2008 | 11:03 AM
kokohead's Avatar
kokohead
Thumbs up 27F Interstate Battery
Sam's Club has the 27F INTERSTATE battery for $80, this is the exact Lexus branded battery with 84 months warranty for $130 + $40 installation.
Old Jul 28, 2008 | 04:08 PM
itsZep's Avatar
itsZep
I was a bit surprised when I took my 2004 GX in recently for a pre-vacation check-up and they said my battery was not in good shape. I asked how much it would be to replace it and they said "oh thats under warranty...it won't cost a thing". It's hard to beat that price and I do not have an extended warranty.
Old Jul 28, 2008 | 04:34 PM
BurgBoxstr's Avatar
BurgBoxstr
Originally Posted by Capirato
The 24F is the replacement size for the truck, NOT the 27F.
The 24F was listed at all the four places I went looking for a battery for the GX.
~ Cap
24F will work...... but it's only applicable in WARM climates
27F is applicable for both warm or cold
Did Lexus really put in 2 types of batteries?
Even if one came w/ a 24F, replacing w/ a 27F will not hurt one tiny bit - probably would be better. Based on CCAs, no sense cutting short what you might need someday as Murphy's Law shall prevail..... My OEM Panasonic battery was definitely 27F series. I'd recommend people replace w/ what [size] came stock.
Incidentally, I'm surprised a 24F fit w/out cable extension(s). That was not my experience when I replaced w/ an Optima 34R (which is the same size IIRC). Details?
Old Jul 28, 2008 | 06:26 PM
BurgBoxstr's Avatar
BurgBoxstr
The 24F is 11 inches long and the 27F is 12 1/2 inches long.
Yes 27F is longer than 24F.
According to every parts store and battery website I went to, The OE group size for the Lexus GX470 is 27F. Sears, yeah the sharpest knife in the retail (and automotive) drawer , says 24F is ok...... in warm climates but recommends the 27F. Are they all wrong?
I didn't replace w/ a 27F in (b/c I chose Optima) but IIRC my OEM battery was 12 7/8" or very close and I'm sure the tray could handle it (I'll measure tomorrow).
You didn't answer my question.....
Did your 24F fit w/out cable extensions?
My Optima 34R required a 2" extension on the ground and it measures in at 10" (my issue was how far in the posts are mounted on optima R so may not have been an issue w/ you?).
The other problem people may run into is a lot of 24F batteries have less CCAs than 27F. I think the lowest 27F I saw was 650 CCA's while I've seen some 24F ~ 500CCAs. In a warmer climates, not an issue, but where it's cool let alone cold.... 24F could certainly leave you SOL....
Old Sep 8, 2008 | 08:14 AM
cmarshack's Avatar
cmarshack
Sorry I didn't answer, because the question didn't make sense to me.
The 24F is an exact replica of the OEM battery, therefore the cables fit perfectly on the 24F replacement battery.
~ Cap
I just bought the OEM replacement from Lexus on Saturday and it's definately a 27F. Cost $110 bucks and was exactly the same size as the Panasonic that I pulled out. I wonder why yours is a 24F? Maybe they did put two different battaries in these trucks.
Old Oct 12, 2009 | 08:58 PM
ERC4's Avatar
ERC4
Chad,
What's the brand and model of battery that you got from Lexus? Was the $110 installed or just for the battery alone?
Thanks,
Gene
Old Jan 26, 2022 | 02:22 AM
maimou's Avatar
maimou
Even if one came w/ a 24F, replacing w/ a 27F will not hurt one tiny bit - probably would be better. Based on CCAs, no sense cutting short what you might need someday as Murphy's Law shall prevail..... My OEM Panasonic battery was definitely 27F series. I'd recommend people replace w/ what came stock.
So I replaced the battery in our 2004 GX470 with an AGM 24F from Costco. It absolutely sucks in cold weather and actually didn't start once so far this winter. It is 2 years old. I noticed last winter that it was very slow to start but didn't think it was the battery as it was almost new.
The only battery offered at Costco for this vehicle is the 24F.
I'm curious where you get the info about the 24F for warm climates?
All the web sites but Costco seem to say 27F for this vehicle.
Old Jan 26, 2022 | 05:27 AM
mntntrls71's Avatar
mntntrls71
I have had bad luck with Optima . I only use Interstate and they have never failed. Even when winching.
Old Jan 26, 2022 | 08:22 PM
EddieK05's Avatar
EddieK05
Costco carries 27F batteries, I just bought one for the GX three months ago. They're Interstate-branded batteries with a full three year, non-prorated warranty.
Old Jan 27, 2022 | 04:59 AM
chiph9's Avatar
chiph9
Not every Costco carries the 27F.
I just buy them at the dealer. It's like $20-30 more than Autozone and I don't have to reenter my radio stations and calibrate the auto-up windows, since they use a jump box to preserve the settings.
There's only 2 battery makers anyway - the differences are mostly branding
Chip H.
Old Jan 27, 2022 | 06:00 AM
IanB2's Avatar
IanB2
Chip H.
Warranty at the dealer is garbage though. When I first got our GX460 the battery wouldn't start the truck even after charging, it was obviously compromised. Lexus said they had to run it through their diagnostics before they could warranty it, well wouldn't you know it passed their tests, no warranty replacement, and billed for an hour of diagnostic time, I was all the way unimpressed. Costco warranty can't be beat.
Old Feb 8, 2022 | 03:36 PM
MAGX470's Avatar
MAGX470
***First Post***
I found a Duralast Gold (750CCA) at AutoZone here just north of Seattle at AutoZone.....in stock suprisingly for ~$140 I think
Old Feb 28, 2022 | 03:17 PM
MDSteamer's Avatar
MDSteamer
I went to Walmart and got an Everstart 27F 24 month for $49 pre covid. My wife's car needed a battery for her Nissan Rouge , prices are nuts , so I picked up an Exide 35 at Home Depot for $99. About 1/3rd less than most auto stores. I keep a 1000w jump starter charged just in case.
anesthesia
Jan 5, 2017 12:24 PM
Stroock639
Feb 21, 2016 07:07 PM
TLPLEXUS
HS 250h Model (2010-2012)
Aug 12, 2015 11:49 AM
truenoboy
Sep 11, 2008 07:06 AM
JCtx
Feb 19, 2008 09:13 AM
