I have a 2001 LS430 UL,
my check engine light comes on when its cold, but it goes out after a day or 2, i had my freind check the codes it was P0172, P1125, TPS....
but right after he pullued his snap on scanner, the VSC off and a VSC message appeared. its been a couple of weeks, my check engine light is off, but the VSC off still on, and the cruise control doesnt work either, it says check cruise system, but i think its related to the VSC being on,
is there a way to reset the VSC light ?
thanks
thanks
since its a UL, you have laser cruise, correct? there could be a problem with you laser sonar. more than likely the vehicle has codes stored for the VSC system. the dealer can pull the codes for you, but they might charge you. you are really going to need those codes to go any further. did you have the TPS fixed/diagnosed?
I think you have a point,
I had the car checked by the dealer, they said they couldnt find any problem with with the TPS, and there was no engine codes, however they found the other codes, for the YAW sensor, and the laser cruise,
they suggested that the laser cruise is triggered by the Vsc, and they wanted to change the Yaw rate sensor for 870$ total, but i thought that i the light just came on when i had a generic scanner plugged to the car,,
Well, I guess after reading a lot of threads about the VSC, I need to recalibrate my yaw rate sensor.
my frfreind has a snap on ( solus) sacnning tool, can it be able to reaclibrate the sensor,...dealer quote me 775$ to do the job...
please advise, thanks....
my car had the same problem......a friend had the modiis scanner by snap on and recalibrate it it no time
got the problem fixed!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
finally, i reset the vsc light by jumping Ts and Gc connectors, waited till i got a message vsc test,
shut off the car, took the jumper out....voila...lights off,,,,,
So what was the exact procedure you did to get your VSC light off? Where are the Ts and Gc connectors you mentioned? I am having the same problem. Thanks
This is an old post but, I had my check engine light checked. As soon as the next time I started the car, the Check VSC would come on, disabling VSC. I tried this reset and it works now.
