Help! Lexus IS 350 tire sensor issue
Old 09-30-07, 10:49 AM
Prowlerjm
Prowlerjm's Avatar
Default Help! Lexus IS 350 tire sensor issue
Hi all, I have a 2 month old '07 IS 350 with about 1200 miles on it.
I had the Low Tire warning go off about a week ago so I filled up the tires and reset it.
Yesterday the low tire warning came on again. It seems like its way too soon.
I'm going to go out in a bit and put more air in, but do you think it could be one of the tires that is bad, or the sensor? Thanks.
Old 09-30-07, 10:50 AM
Hartawan
Former Vendor
Hartawan's Avatar
How about checking your tires with a pressure guage when your light comes on and see if it is a bad tire.
Old 09-30-07, 11:14 AM
as3.0cl
as3.0cl's Avatar
nail in the tire
Old 09-30-07, 01:24 PM
Evitzee
Evitzee's Avatar
Don't shoot the messenger. The system is telling you you have a problem with one of the tires. Look for a nail.
It's too bad that the Lexus system won't pinpoint which tire it is rather than making you crawl around and check each wheel. Lexus can do better with this system.
Old 09-30-07, 03:12 PM
Bichon
Super Moderator
Senior Moderator
Bichon's Avatar
Also, make sure you filled them to the pressure on the door jamb: 35 front, 37 rear when cold.
Old 10-02-07, 07:05 PM
ARISTO26
ARISTO26's Avatar
If not take it to the dealer cause it happen to those cars in the begging and they cange the sensor, it should be under warranty anyway.
Old 10-02-07, 07:53 PM
datboililp
datboililp's Avatar
i have the same problem.
Old 10-02-07, 08:27 PM
GenIs2
GenIs2's Avatar
It is probably the spare tire. The spare tire has a sensor also and the low tire warning just went off for me a couple days ago. Just fill it up to 60 psi, I know wtf 60psi! and drive around for about 15 mins and it will go away. If not then one of your tires has a nail or something.
Old 10-02-07, 09:55 PM
Bichon
Super Moderator
Senior Moderator
Bichon's Avatar
The spare tire does not have a sensor.
Old 10-02-07, 11:59 PM
isam250
isam250's Avatar
nail in the tire
Old 10-03-07, 04:21 AM
tex2670
tex2670's Avatar
Does Fix a Flat mess up the TPMS sensors?
trungerton
LX - 3rd Gen (2008-2021)
13
11-23-15 07:10 AM
cfretwel
12-24-11 08:14 AM
tripplej
02-16-11 03:48 PM
Missis250
11-12-10 12:22 PM
Quick Reply: Help! Lexus IS 350 tire sensor issue
