- Install turbo manifold
- Mount the turbo on manifold
- Rerouted heater core tubing
- Drained engine oil
- Ran the oil feed line
- Mounted the downpipe
- Wiped down engine bay
- A bunch of test fitting and measuring
I will be drilling the oil pan and fabricating some intercooler piping tomorrow. I'll keep up with the pix. I'm aiming for my project to be completed by this Saturday so I'll be ready in time for the Sunday Clublexus meet here in the Dallas area.
On with the Pix!
Basically stock under there
Stock intake removed
Bumper removed
Picture with the bumper out of the way
Jack up the car
Jacked up the car from the crossmember. This is where you're supposed to jack the car up from when you're servicing it. Close up pic for those of you that don't know where it is.
guh. i hate how the crossmember is so far back. I have to drive my car on wooden blocks to even let the jack underneath. One of these days i'm going to invest in an AC Jack
Milky: What I do is drive my car on two pieces of wood first. That elevates the car high enough to slide the jack all the way down to the crossmember.
Jeff: Everything looks good so far. What I hated about installing my custom turbo set up on my Mustang was tapping next to the oil filter for the oil feed line and tapping into the oil pan for the oil drain. The metal on the oil pan was so thin there was little room for error.
what size is your innercooler? is it 12x24x3"
i think i have the same turbo as you. xs power?
The two manifolds are exactly the same. I got a spare in case one cracks or something lol...not to mention I got the extra one for dirt cheap. As for the turbo it's a Turbonetics 62-1 turbo. I didn't go cheap on any of the critical parts (turbo, wastegate, bov). I only went a little cheap on the manifold and intercooler (both made by XSPower). gYWKR
