How to reset "maintenance reminder" light?
Anyone know a trick to resetting the maintenance warning light after an oil change. Would a Peak code reader from Autozone or somewhere do the trick or can you jumper a couple connections somewhere?
Don't want to have to take to dealer for a $190 oil change if you know what I mean.
Didn't mean for response to be snarky. I've had to do the reset myself a few times as it's over 100 miles (one way) to the Lexus dealer and only like 10 to our local Toyota dealer - they don't have a clue on resetting the maintenance light, but they are like $40+ cheaper for an oil change. Of course you don't get your car hand-dried either.....
Help,
I did what you said (ODO -> LOCK -> hold the trip meter reset button ->Start-> continue hold the button at least 10 seconds), didn't work, the light is still ON.
My car is a 2007 RX350 with Navigation.
Appreciate your advices!
Maintenance Reset
Minkel, should work the same whether it’s a 330 or 350. I believe that you need to watch the odometer count down, rather than relying on just waiting 10 seconds or so. Lets go through procedure again;
1.) Make sure odometer shows mileage (not trip A or B) 2.) With odometer showing, shut off ignition. 3.) While pressing the odometer/trip mileage button, turn ignition to ‘ON’. 4.) Hold button in and watch until the odometer reading turns back to straight lines.
This has always worked for me, and I’ve done it several times.
Cheers
Cheers
Thank you Orzel.
It seems the step 4) in your post is a little tricky...
I have tried several times, step 1) to 3) are exactly as you described.
However, in step 4), it displays ODO reading and never changes..
Hmmmm, I was under the impression that the 330 and 350 were the same in that context. My neighbors 350 reset easily with those procedures. I'm guessing at this point you may want to try the owners manual, as there may be a slight difference between the late 330, early 350 and current 350. Otherwise, I'm stumped.
Joseph22T
IS - 1st Gen (2001-2005)
01-12-13 03:05 PM
