Rubbing on 20's?
Old Jan 7, 2007 | 11:23 PM
ttran076's Avatar
ttran076
Default Rubbing on 20's?
Just wondering if any of you guys with 20's and lowered have rubbing issues? If so how did you fix them?
Old Jan 8, 2007 | 03:56 AM
akim47's Avatar
akim47
roll your fenders... my rears don't have any problem, the front still rubs inside the wheel well...
Old Jan 8, 2007 | 05:44 AM
UAE GS430's Avatar
UAE GS430
yes roll the reae finders i did mine my G running on 20s
Old Jan 8, 2007 | 06:29 PM
leestoy's Avatar
leestoy
Hey Ttran, What Size Tires Are You Running???? Thanks
Old Jan 9, 2007 | 01:40 AM
akim47's Avatar
akim47
i dont know what part of CA you are in...
if ur in socal, u can pay to get it done. Try shorline motoring...
www.shorelinemotoring.com
they aren't cheap, but they work on high end cars, and service is top notch... my philosophy is to do it right the first time...
otherwise you can rent
http://www.rollyourfender.com/
my friend works on a lot of cars, so he purchased the tool... works really well, he just did his s13...
Old Jan 9, 2007 | 01:58 PM
leestoy's Avatar
leestoy
ttran,
i was told that running 245/30 and 285/25 should save you from rubbing... just my $.02... That's what they recommended me when i purchased my rims/tires and lowering aggressively...
Old Jan 20, 2007 | 01:32 AM
GSFKN3's Avatar
GSFKN3
my 06 GS is slammed!!!!! with tein coilovers, and 20" iforged seneka's. I grinded the rear fenders with a sanding wheel. More towards the rear bumper to the center. It clears perfect now. The front sucks. All I can say is be sure you angle the car, then drive into the drive way with the wheels straight. Depending on the drive way, you might scratch yout front. I got a Wald kit, but with 20"s you'll clear. Mine car nips the from lip. But I had my front fender pulled out cause I had the wheel turned to the left as I went into a drive way. That sucked!!!!!
Old Jan 21, 2007 | 02:33 AM
Neo's Avatar
Neo
The One
Have you determined where the rub is? What are the wheel specs?
Old Jan 21, 2007 | 07:33 AM
okcfunky's Avatar
okcfunky
245/35's rub. I've almost rubbed completely through the offset inside lip (like 1/2 inch inside from the exterior lip) and with just NF210's.
Old Jan 21, 2007 | 09:50 AM
IS_250's Avatar
IS_250
Originally Posted by ttran076
Just wondering if any of you guys with 20's and lowered have rubbing issues? If so how did you fix them? I got 20's with Tein CS-T and still got rubbing issues. The back rubs when I come up a steep driveway. And everything rubs when I come down hard on a bounce. Thanks for your help.
as others had asked, whats the offset and width of your wheels? if your offsets are way off, there is no amount of fender rolling that can help you.
Old Jan 29, 2007 | 12:52 PM
siikwidit's Avatar
siikwidit
You're prob just running the wrong size tires....With custom built wheels you SHOULD NOT have to grind away or cut anything. There should be a standard recommended fitment with the correct size tires to accomodate the plus sized wheels.
Old Jan 29, 2007 | 01:53 PM
carnac's Avatar
carnac
What offset do you run with the 20's?
Old Jan 29, 2007 | 08:11 PM
nardeezy's Avatar
nardeezy
My setup rubs just like everyone eles'e.
Old Jan 30, 2007 | 01:39 PM
leestoy's Avatar
leestoy
I do not have any rubbing issues whatsoever.... I have 20x8.5 F running 245/30/20 and 20x10 R running 285/25/20 and I am aggressively lowered with coilovers... about 2-1/4" of lowering.....
Old Jan 30, 2007 | 02:45 PM
Neo's Avatar
Neo
The One
It helps that you are running at OEM diameters. Not too much rubber though.
