Rubbing on 20's?
Old Jan 30, 2007 | 05:08 PM
leestoy's Avatar
leestoy
Neo, yes it does.... alot of guys are running 245/35 and 275/30 and almost always without shaving the rear fenders are rubbing... i have about 3/4 finger gap all the way and no rubbing at all.. as far as the rubber goes, yes it's definitely not a whole lot but i tell you what with the JIC coilovers the car rides incredible... I feel the road more because of the tire thickness but it really does ride really good.. I know alot of you guys won't believe me but it almost rides better than stock... just my $.02
Old Jan 31, 2007 | 03:29 PM
akim47's Avatar
akim47
20 x 10 in rear - 47 offset (work O disk)
20 x 8.5 in front +42 (big caliper)
245/35/20 front
275/30/20 in rear
Old Jan 31, 2007 | 04:01 PM
siikwidit's Avatar
siikwidit
After tire sizes, it depends also on the brand of tires...For example, michellin ps2's, dunlops and nitto nt-555's run on the bigger side with the same size as say a pirelli p-zero or toyo t1-r. So tire manufacturer and correct pad height on the wheel make a big difference!!
Old Feb 1, 2007 | 06:25 PM
nardeezy's Avatar
nardeezy
Originally Posted by leestoy
I do not have any rubbing issues whatsoever.... I have 20x8.5 F running 245/30/20 and 20x10 R running 285/25/20 and I am aggressively lowered with coilovers... about 2-1/4" of lowering.....
Makes sense, your tire sizes are much more closer to stock than the 35 and 30 series. I think I will change to your aspect ratio when it's time to change tires. I was kind of scared that it would be too thin but I guess between the 35/30 and 30/25 series tires it doesn't matter, the wheel will bend regardless!
Old Feb 2, 2007 | 07:16 AM
leestoy's Avatar
leestoy
That's pretty much right.... But I guarantee you will not rub with these size tires...I have Toyo T1R's... Just in case you wanted to know the brand....
jorgie523
Dec 28, 2011 08:49 PM
offWhite
Dec 7, 2009 03:02 PM
UR2klose
May 18, 2009 01:04 PM
biglexass
Wheels, Tires & Brakes Forum
Jun 15, 2006 05:42 PM
TTurboPimp
70
Apr 15, 2003 05:23 PM
