View Poll Results: which do you prefer?
NGK
130
46.93%
Denso
99
35.74%
Just stick a hampster in each cyl.
48
17.33%
Voters: 277. You may not vote on this poll
iridium plugs - NGK or DENSO?
Old May 17, 2006 | 11:50 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Default iridium plugs - NGK or DENSO?
I'm gonna change the plugs in my IS, figured I'd poll for the best results by users and popular opinion.
Please post up
Old May 18, 2006 | 12:40 PM
Richie's Avatar
Richie
In all my cars to date I've used NGK, they rule!!
Old May 18, 2006 | 12:49 PM
Trexus's Avatar
Trexus
Denso iridiums all the way...
Old May 18, 2006 | 03:55 PM
sonyman's Avatar
sonyman
I really don't think you can go wrong using either one. Both brands are designed with the utmost quality and are built to the exact specifications for our cars. In the past I've bought NGK because they were more readily available as well as a little cheaper, but I'd sway to the Denso side if I found them cheaper instead. Good luck.
Scott
Old May 18, 2006 | 04:16 PM
AZDesertGS's Avatar
AZDesertGS
Scott
Cant go wrong with either one. I just put Densos in last week and all is good
Old May 18, 2006 | 06:00 PM
lexusk8's Avatar
lexusk8
I installed Denso iridium plugs in my ES two years ago when the mileage was close to 90K, and since then I haven't had any problems. The factory ones in my car were the NGK.
Old May 18, 2006 | 06:29 PM
T0ked's Avatar
T0ked
I'm using NGK Iridiums. Just buy which ever is cheaper. I don't you can go wrong with either company.
Old May 18, 2006 | 08:15 PM
Lexbox's Avatar
Lexbox
Please post up
Any thought about getting TM's?
Old May 19, 2006 | 12:57 AM
MGS4's Avatar
MGS4
TRD iridium spark plugs
Old May 19, 2006 | 06:09 AM
CVsIS250's Avatar
CVsIS250
When I owned my 2003 4Runner, I changed the plugs after 30K and found a mixture of the two types in the motor. I called toyota and they said it was pretty normal....wtf??
CV
Old May 19, 2006 | 09:30 AM
Lexmex's Avatar
Lexmex
I have had TMs twice in my RX300. The first time, just a K&N filter and no difference. However, with all my other modifications, big difference and it feels like every last little drop of gas is getting burned cleanly. I would estimate it dropped me at least .1 in the 1/4 mile the first time I tried it. Keep in mind my Denso plugs were less than 1 year old when I put in TMs the second time.
Old May 19, 2006 | 03:26 PM
richonenz's Avatar
richonenz
Denso's have a slightly finer wire than the NGK's , 0.6 to 0.8 I believe , so the Denso's might burn slightly better but won't last as long , I think the factory reccomended mileage is less for the Denso's than the NGK's .
Personally I don't use anything but NGK's !!
Old May 19, 2006 | 03:32 PM
AZDesertGS's Avatar
AZDesertGS
CV
I changed mine in my 04 Tacoma as well and 3 densos on one side and 3 NGK's on the other. Wierd huh???
Old May 20, 2006 | 01:06 AM
TTEHarrier's Avatar
TTEHarrier
Old May 20, 2006 | 10:56 AM
engin_ear's Avatar
engin_ear
Everything in Moderation
I've used 'em both. It's really hard to pick one over the other. Both are the best plugs I've used.
However, I just put in Torquemasters (TMs). GS is now like a rocket ship. Unfreakinbelievable.
