do springs work w/ 19" fat setup?
Old May 1, 2006 | 04:48 PM
ECUgs430's Avatar
ECUgs430
Default do springs work w/ 19" fat setup?
I need help from yall with the 245/40/19 275/35/19 setup. I have no suspension mods yet. Im considering the h-tech's bc of the 1" drop with slightly more in the front. It seems great for the price. Would I need new shocks? Any tein problems? Any body have pics of similar set ups? and whats the best way to get rid of the inner rear fender lip thats rubbing now? Thanks!
Old May 1, 2006 | 05:13 PM
BC-GS430's Avatar
BC-GS430
CL Folding 500,000
Springs will work fine in a fat setup. It would be better if you got new shocks that are matched to the springs otherwise they will wear faster. It's rubbing with no suspension mods? I never rubbed with my 19's with fat setup before I dropped it. Unless your offset is pretty agressive. Hopefully Rominl or Neo will pop in here with a better reply.
Old May 1, 2006 | 05:28 PM
Neo's Avatar
Neo
The One
The springs should work but like BC said, the shocks will wear a bit faster. It does not mean that your shocks will go in 1k miles, 5k miles, ... It just means faster than it would have with the OEM shocks. It is hard to say. The ride and handling will also be a little suspect as the spring rate and shocks may not work optimally. Notice that there are a lot of mays and mights since it all depends on the current condition of the components, the roads you drive on, your driving style, your sensitivities, ...
As for the lip, depending on how bad the rub is, rolling or cutting are the two methods. What are the offsets? 9.5 with 275s and already rubbing. Hmm.
Old May 1, 2006 | 06:08 PM
ECUgs430's Avatar
ECUgs430
Thanks for the feedback. Yeah, it does rub but only in the rear on the pasenger side. The tire on that side sticks out a little further than driver side does. It is actually cutting into the tire on the side wall were the tread pattern ends. Not too bad yet. Maybe I need a rear alignment . Is this different than a regular alignment ? bc the car drives fine and has never pulled in either direction.
Old May 2, 2006 | 01:09 PM
400DGRZ's Avatar
400DGRZ
I used to have the Daizen springs (1.9, 1.7), L-Tuned shocks, and staggered 19"(38F, 45R). I had no rubbing...........
IndySC300
Mar 4, 2011 10:45 AM
gman44116
Suspension and Brakes
Oct 23, 2009 08:44 AM
DONT SLEEP
Aug 9, 2009 04:53 PM
AdrockTT
15
Feb 19, 2008 07:06 PM
