Build Threads Details on Club Lexus 2GS owner vehicles
My GS400 modding journal - commenced Feb. 2003
Old May 24, 2005 | 06:55 AM
  #646
Hameed's Avatar
Hameed
EV ftw!!!
Originally Posted by PHML
LOL...ok threadjackers...back to the topic.
Hameed, whats a reasonable timetable for these? Fall 2005? Winter 2005? Spring 2006?
Obviously, the list of peeps is growing for this.
Pete
I am shooting for before end of Summer 2005. I will keep you all posted!!!
Old May 24, 2005 | 07:26 AM
  #647
chicagoblknazn's Avatar
chicagoblknazn
I want a set!!!!!!
Great job Hameed.....they really look nice.
Old May 24, 2005 | 10:08 AM
  #648
jtanoyo1's Avatar
jtanoyo1
Originally Posted by Hameed
Thanks Dave and Ethan!!!
I need a couple of weeks to get certain business things in order as the mirror blinker mod needs a couple of very minor imperfections to be ironed out before I can sell it. We are all very **** about quality (a good thing, nothing bad about that) and the last thing I want to have to deal with when I start selling these is to field complaints. I will keep you all posted!
Yes, it is built in. I will take a video of it during daytime and nighttime so that you can see how cool it is!
Can you show us what this load equalizer thing is? I am quite curious about what it does...
Old May 24, 2005 | 10:09 AM
  #649
Ladyt's Avatar
Ladyt
Love Them. I would also love to have a pair.
Old May 24, 2005 | 10:26 AM
  #650
Hameed's Avatar
Hameed
EV ftw!!!
Why do you need a resistor with an LED? The short answer: to limit the current in the LED to a safe value.
The long answer: LEDs are semiconductors, diodes in particular. The current flowing in an LED is an exponential function of voltage across the LED. The important part about that for you is that a small change in voltage can produce a huge change in current. That is the most important concept of this article. Resistors aren’t like that. The current and voltage in a resistor are linearly related. That means that a change in voltage will produce a proportional change in current. Current versus voltage is a straight line for a resistor, but not at all for an LED.
Because of this, you can’t say that LEDs have “resistance.” Resistance is defined as the constant ratio of voltage to current in a resistive circuit element. Even worse, there’s no real way to know exactly the relationship between current and voltage for any given LED across all possible voltages other than direct measurement. The exact relationship varies among different colors, different sizes, and even different batches from the same manufacturer. When you buy an LED, it should come with a rating that looks like this: 3.3V @ 20 mA typical. That gives you one point along the operating curve. Usually that’s a safe operating point. You may get a maximum rating in addition. It may be in the form of either a voltage or current. For example, a lot of people report buying “5V blue LEDs.” These are really not rated to operate continuously at 5V in most cases.
The other thing I’d like you to take away from this article is the idea that it’s more useful to talk about driving an LED with a current of a particular size, instead of a voltage. If you know the voltage across an LED, you can not determine the current flowing in it, unless you are operating it at the exact point along the curve that’s described in the specs. Worse, being “off by a little” in the forward voltage can have a drastic effect in the current. So the approach I prefer is to select a current-limiting resistor in order to achieve a target current in the LED.
Most 3mm and 5mm LEDs will operate close to their peak brightness at a drive current of 20 mA. This is a conservative current: it doesn’t exceed most ratings (your specs may vary, or you may not have any specs–in this case 20 mA is a good default guess). In most cases, driving the LED at a higher current will not produce substantial additional light. Instead, the junction (the working parts of the LED) has to dissipate the excess power as heat. Heating the junction will decrease its useful life, and can reduce the output of the LED substantially. Heating it enough will cause catastrophic failure (producing a dark emitting diode).
Old May 24, 2005 | 10:36 AM
  #651
sputniknyc's Avatar
sputniknyc
and THAT is what makes time travel possible!
Old May 24, 2005 | 10:37 AM
  #652
chicagoblknazn
You and your fancy words
Old May 24, 2005 | 10:45 AM
  #653
GS wanted's Avatar
GS wanted
I use CL as an escape from work only to see explanations like this and be reminded of work.
Old May 24, 2005 | 11:35 AM
  #654
svt5150's Avatar
svt5150
Any word on these yet? They look great Hameed
Old May 24, 2005 | 01:38 PM
  #655
rominl's Avatar
rominl
exclusive matchup
amen to that! i come here during my lunch break hoping for a little break damnit @_@ now i remember all the simulations i have been running @_@
Old May 24, 2005 | 01:42 PM
  #656
PHML's Avatar
PHML
Master Thread Closer!!
Dude...where did u plagiarize this from?
Old May 24, 2005 | 02:00 PM
  #657
Capirato's Avatar
Capirato
Dude...
http://led.linear1.org/why-do-i-need...r-with-an-led/
Go to Page 2 for more info.
~ Cap
Old May 24, 2005 | 02:06 PM
  #658
Alexus-Kia's Avatar
Alexus-Kia
ME WANT SOME!!!!
Welp. there goes me not using my credit card i gotta get these!!
Old May 24, 2005 | 07:07 PM
  #659
jtanoyo1's Avatar
jtanoyo1
This might be true if the LED in question is single diode unit and if the power source is greater than the usual 5W. Anything bigger than that will cause the LED to blow, thus rendering the need for a separate resistor. As I understand it, these Mercedes blinkers act as solitary light unit not as "LED"s and only have 2 wires (+ and -) coming out of it that you only need to hook onto your headlight blinkers and they will perform just like normal blinkers. You don't need resistors to make it work as normal.
Old May 26, 2005 | 07:31 PM
  #660
aristogs05's Avatar
aristogs05
what happened to this mod? When will it be available?
