Replacement Tires?
Old Mar 23, 2002 | 08:50 PM
GR8WHTLEX's Avatar
GR8WHTLEX
Default Replacement Tires?
I need to replace my Fulda's in the next couple of thousand miles and I'm trying to narrow my options.
My GS 400 is the first car that I've owned that has such a horrible problem with "tramlining". When I'm driving on anything less than a perfectly smooth road, the tires are constantly trying to follow the grooves or uneven edges of the street. I really have to pay attention to the steering wheel or it will try to change lanes. I've read several posts that talk about the fact that low profile tires have this issue so I guess it's to be expected from 235/45/17 size tires. I just don't remember my Talon having this problem but the tires weren't quite as wide nor as low profile.
Does anyone have any advice on what brand of tires would exhibit this behavior the least? Does everyone else have this problem? Do "directional" tires have this issue more than a tire that is "assimetric"?
Old Mar 27, 2002 | 09:10 PM
gurrola2001's Avatar
gurrola2001
Bridgestone have been really good on GS. Im not a tire expert but that is my best bet.
Old Mar 28, 2002 | 06:08 AM
Navaz's Avatar
Navaz
You should try the Bridgstone Potenza RE 730. I have them helped out with the problem you got, They also last forever compared to other Z rated tires and they are Quiet. You should also get the L-tuned ECU upgrade and your problem will be memories!.
Old Mar 29, 2002 | 01:46 PM
blue wax's Avatar
blue wax
I've changed to semperit sports tires....
use to have bridgestone potenza
semperit is good to up 270 Km/h.
is softer and smoother on railroad tracks etc.. but they won't last that long, anyway your car will sit as glued to the road, a superb tire, the best I've ever had until now....... and I've been using a lot of top brands too
just try them
Old Mar 29, 2002 | 08:34 PM
mayandoom's Avatar
mayandoom
Default ??
Riding the grooves is a problem associated with the tires, not the car.
That said.
Bridgestone RE950's are xlnt tires
Kumho's 712's are also xlnt, especially when you consider the price. Many track runners are using these tires now.
You will find both much quieter than the Fulda's you are running with the advantage of better wet -dry traction.
ephisig764
Oct 8, 2011 11:49 AM
sleeper408
Jul 3, 2008 10:03 AM
kloh7
Jan 31, 2007 01:47 PM
Bahadur
Jan 21, 2004 11:04 PM
1NICESC430
May 14, 2003 02:47 PM
