offset question
Old Aug 30, 2007 | 07:43 AM
boosted-gs's Avatar
boosted-gs
Default offset question
i was just wondering how these offsets would look on my car which is a gs300 99. like will they sit to far in or sit to far out?
19*8 with a 34-36 offset and a
19*10 for the rear with a 40 offset
with 235/35/19 tires
and 275/30/19 for the rear...
thanks
Old Aug 30, 2007 | 09:00 AM
rominl's Avatar
rominl
exclusive matchup
the front is very safe
the rear you might rub a bit but take off the fender tab or maybe shave a little and you are good to go
Old Aug 30, 2007 | 09:08 AM
V8_Aristo's Avatar
V8_Aristo
Bippu
This will depend on how low you are, since wheel clearance from the fender get deeper the lower you go. At stock height to an inch drop, it will look almost flush.
Old Aug 30, 2007 | 09:26 AM
boosted-gs's Avatar
boosted-gs
well i'm not planning to drop that much maybe 1.2 in front and 1.5 in the rear... so you think i'll rub in the rear?
Old Aug 30, 2007 | 10:17 AM
V8_Aristo's Avatar
V8_Aristo
Bippu
I have seen a 19x10 +37 (w/ 275/30/19) fit w/o fender modifications, so a +40 should clear (since it's 3mm deeper). In the event that is does not, you can just unscrew the molding that goes on top of the lip. This simple trick can add another 3mm clearance if you need it.
Sceptre
Oct 1, 2009 08:49 AM
Clifton
Jul 6, 2008 06:10 PM
Koz
Mar 22, 2008 08:09 AM
Gs430Boi
Mar 11, 2008 08:52 PM
808d-no
Dec 20, 2007 05:59 PM
