Wheel Problem
Old Feb 4, 2005 | 10:39 AM
SickSC3's Avatar
SickSC3
Default Wheel Problem
I have a problem I got a set of volk wheels for my sc300. The wheels originally came of the newer GS. However I tried putting them on but I notice that the studs are to short and I can’t bolt it on. So what I have to do is get longer studs correct? Well I called up a wheel shop in my area and they told me that they wouldn’t recommend that and told me to get new wheels. I really don’t want to do that. Is there away around this? Has anybody had this kind of problem?
thanks
Old Feb 4, 2005 | 01:48 PM
rominl's Avatar
rominl
exclusive matchup
i am surprised that the gs wheels fit on your car but the studs are too short. i thought the gs and the sc have about the same length studs. if you get quality studs i think it should be ok. maybe H&R?
Old Feb 4, 2005 | 04:07 PM
SickSC3's Avatar
SickSC3
yeah i really thought they were the same also but i guess on the sc they are shorter alright ill check out the h&r
Old Feb 4, 2005 | 09:06 PM
blueGS400's Avatar
blueGS400
go to a wheel shop in your area and have them test fit them with et shank lugs,,,,,,,,,,u must ask for et, if u get those and you get enough turns to be safe than your good to go, the shank at the end actually goes inside if the hole for the wheel and gets you more bite on the threads of the stud
heres a pic for example
http://infinitemotorsports.com/lugnu...#etconicalseat
Old Feb 4, 2005 | 11:11 PM
FCSmthree's Avatar
FCSmthree
This totally sucks, hopefully there is a cheap and easy solution for you and you're not left in the DARK. I thought all rims on Lexus were interchangeable except for trucks.
Good luck to you and keep us posted
Old Feb 5, 2005 | 01:34 PM
Lexkost's Avatar
Lexkost
I looked into longer studs for a lexus and there are not any out there..........unless you want to do some altering and reboring of the hubs and rotors..............the H&R's are an adopter with studs....your best bet is to get the right wheels .
Old Feb 5, 2005 | 04:31 PM
rominl's Avatar
rominl
exclusive matchup
actually i have seen separate studs from H&R, i forgot which spacer that comes with, 5 or 10mm?
and this is UNOFFICIAL. if you want, look out for the studs from the toyota highlander, 4runner, or the sequoia. i can't confirm, but i heard that they have long studs
Old Feb 5, 2005 | 11:17 PM
SickSC3's Avatar
SickSC3
hey guys thanks for the info. i have a cousin that work for toyota so ill find out sequia, 4runner will work. if anybody has more info. please let me know. wait does anybody know if i buy GS wheel studs will it work?
Old Feb 6, 2005 | 10:20 AM
400DGRZ's Avatar
400DGRZ
It shouldn't have anything to do with the wheels.
The wheels he is referring too are the Volk AV3's that I sold him.
Jack, aka LexusFiend, test fit them on his SC300 with these lugs and they fit fine. No problems. They read 1.5. If you want, I'll ship these to you SickSC3.
Old Feb 6, 2005 | 11:59 AM
rominl's Avatar
rominl
exclusive matchup
oh so this is the reason.... yeah, you can't just use any lug nuts, the av3 have their own different type of lug nuts, you have to use these specificially! i am pretty sure with the corrent lug nuts it will fit for sure
Old Feb 7, 2005 | 11:40 AM
SickSC3's Avatar
SickSC3
thanks guys
YxUxMADDDD
Dec 30, 2016 06:45 PM
ek9vboi
Mar 13, 2008 05:29 PM
SoCalSC4
Dec 5, 2006 11:07 PM
twentyone
Mar 27, 2006 09:52 AM
spyder357
May 5, 2005 09:12 PM
