Tire sizing help!..
Hey all,
I searched but didnt help so heres my question, will a 275/35zr/19 tire cause rubbing on my 93 sc400?? Or any other prolblem I might not be aware of?
Thanks for the help everyone
if you're going to do 275-35-19 then up front you SHOULD be going for 245-40-19 to even both ends out. But i don't think you're going to rub, but mainly depends on how LOW you are going to lower your car.
I was thinking about this setup but decided not to. The rears shouldn't be too much of a problem, but the front might rub hard when the springs compress and the tire hits the top lining where the wires are located (manaray). other than that, no problem!
edit: i had 245-35-19 and 275-30-19 combo on my 93' SC.
Originally posted by =BANKS=
what if they are 275's all around?? Is that a problem?
it will DEFINITELY rub. i think i've heard 255 for the fronts, but not 275.
Originally posted by rominl
actually if you have the perfectly right offset, 275/30/19 in the front will work
no doubt it would look awesome, but man, if you're buying the rims from your friend then you can't get the "custom" offset that you need, unless it's from the same car or maybe the same company. who knows, but show us some pics if you decide to get them!
Originally posted by do-luck sc
that's true henry, but even with the right offset, wouldn't it rub the control arms when you make any sort of turn? or what about when you lower your car? a guy in hawaii had some 19x9.5 in front i believe, i forget, but his tires were stretched JDM style in order to make them fit.
i think 275/30/19 should be ok coz' it's the same as 245/35/19, height wise?
futuregs
Wheels, Tires & Brakes Forum
Mar 28, 2002 03:45 PM
