How to get more negative camber?
Old 05-11-13, 11:36 AM
koksik
koksik's Avatar
Default How to get more negative camber?
Im looking to put really agressive wheels under my IS but camber arms for my car can give me max -3deg of neg camber. I was looking to get lower arm but I might get only -3 as well...
Can I use both and are they give me -6 in total? otherwise what You guys doing to have crazy negative camber??
Old 05-11-13, 03:06 PM
SoCal_450h
SoCal_450h's Avatar
I'm using Megan camber and toe combo and I'm on -4.5 and still can go for more
Old 05-11-13, 11:42 PM
koksik
koksik's Avatar
But you have gs?? Is there differents in arms for gs and is? Whitch arms You have?
Old 05-12-13, 08:00 AM
SoCal_450h
SoCal_450h's Avatar
I thought IS and GS are similar? Because when I bought, it said for ISx50, they don't have for GS.
Toe
Camber
or you could go with FIGs, they are high quality build.
Old 05-12-13, 06:42 PM
koksik
koksik's Avatar
do You know how much I can get with figs???
Old 05-12-13, 07:24 PM
SoCal_450h
SoCal_450h's Avatar
I don't want to give you wrong info, you could ask him, he's a vendor in CL.
or you could check his website http://www.shopfigs.com/v1/
Old 07-31-13, 07:22 PM
Sffd103
Fire Slayer
Sffd103's Avatar
That's probably the most you'll get Koksik. I have the Megan camber arms maxed out. I also have but haven't installed the Figs toe links and Mega arms.
Old 08-14-13, 11:55 AM
Jump2man3
Jump2man3's Avatar
Agreed. I can chime in for the Mega Arms/Toe Links. You will get alot of play with those products. Im currently running on my -IS- SPC front rear camber kit with the FIGS mega arms and toe links very nasty set up and can be totally adjustable. Im right now at a -2 rear and my aligment guy said there is more to go if need be. Check Figs out talk to Mike the owner he is a great guy he might even chime in with a better spec on camber with his products.
Old 08-17-13, 02:17 PM
FIGS
The Maker
FIGS's Avatar
We now have every link in the rear from Toe,Trac, Rear LCA and the 2 upper links. I am still not sure why the other companies only make 1 upper link, just seems ill advised to make and adjustment on a multi-link configuration with only one link on a major axes.
we can built to spec, so you can tell us how long to build them and we will do it. Its just a little more based on materials.
Uppers, we can make shorter for more camber.
http://shopfigs.com/v1/index.php?rou...product_id=179
Rear LCA, and Trac and toe links can all be made longer for more camber
http://shopfigs.com/v1/index.php?rou...&product_id=81
http://shopfigs.com/v1/index.php?rou...&product_id=55
http://shopfigs.com/v1/index.php?rou...product_id=207
we also make a front upper bushing that you can add another .5 negative. Its not much but easily installed. I have them on a super special since we have a lot in stock.
http://shopfigs.com/v1/index.php?rou...product_id=197
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 10-22-13, 09:36 AM
levie
levie's Avatar
let us know how much camber you end up with man.
HizGSF
Suspension
37
08-29-13 11:44 PM
ozzy250
Suspension and Brakes
04-19-13 12:42 PM
671IS250
06-13-11 10:28 PM
ShaneC
57
02-12-09 02:40 AM
smokeganja
05-07-08 01:04 PM
Quick Reply: How to get more negative camber?
