Cut my coils to lower my ls400
Old 08-22-11, 05:51 AM
Schnitz
Schnitz's Avatar
The cars worth maybe $4k. Cut the springs as see how you like it.
All this, " it'll ride thike crap" is nonsense. I've been in many a ride with cut springs that rode just fine. That being said, you cut too much and it will ride like crap.
My $0.02 buy a set of used Megan's (~$500) and call it a day.
Hydros done right will definitely cost at least $2000. I was comparing both systems before I went air.
Old 08-22-11, 09:33 AM
LiCelsior
Retired
LiCelsior's Avatar
yea hydraulics are cheaper than 1800 if u dont run any accumulators but thats basically riding with no springs.
Old 08-22-11, 10:05 AM
LS400BOY
LS400BOY's Avatar
i know if i cut a turn or 2 off it woudnt hurt that bad
Old 08-22-11, 12:09 PM
klepto
klepto's Avatar
Originally Posted by LiCelsior
springs, 200-300.
coilovers, 650-1100.
airbags or hydraulics, 1800-4000
take ur pick.
cutting/heating coils is dangerous. At the very least springs can be had for cheap.
Old 08-24-11, 02:41 AM
NZLou
NZLou's Avatar
Cutting is only dangerous if you cut too much off and then are no longer captive.
Heating springs is common practice. Only bad experience I've ever had is they tend to sag over time. Which would probably happen quite fast given the weight of the car.
$500 for a second hand set of coilovers would be the go. Just make sure they are good to go as rebuilding can cost alot more than they are worth.
Old 08-24-11, 07:44 AM
IXI187IXI
IXI187IXI's Avatar
the amount of money you will save by doing it right the first time will be far less then the amount you will spend when you damage suspension parts or possible crash your car.
heres a good article on springs to give you a good understanding
Spring Rates and Progressive vs Linear
Old 08-25-11, 07:07 PM
lexusondubs
dubsonlexus
lexusondubs's Avatar
lol its a lexus not a honda do it right the first time
Old 11-15-13, 06:48 AM
nandob
nandob's Avatar
I totally agree with Schnitz, most people that say don't do it havent done it. I had my springs heated on my 96 while I was $250 short for coilovers and it still rode fine. I had mine heated by a professional. An old school guy that knew what he was doing. So with that being said I would have them heated by a professional my car wasn't all that bouncy it rode just fine. And even when I got my coilovers I didnt rush to install them because to me my car rode fine. I wouldn't advise cutting but heat compression IMO is the best way to go and in the meantime save for coilovers.
Old 11-16-13, 11:32 PM
Sc0pe
Sc0pe's Avatar
Why not just buy Tanabe DF-210s? They're about ~$215 shipped from here.
Old 11-17-13, 07:51 AM
whit3b0y
whit3b0y's Avatar
Id you heat your coils they will not stop lowering/compressing. Cutting will remove part of the spring, removing part of the comfort. I have a set of df210's ill sell for about 20 + shipping
Old 11-18-13, 06:30 AM
nandob
nandob's Avatar
Hey I will take those off your hands since I now have a 99 and I swapped my coils from my 96 shipping to 75232 text me 214-916-8196
Old 11-19-13, 09:21 PM
iamjosan
iamjosan's Avatar
If you want to go low on 18s you're gonna need some good coilovers. I have Stance GR+ on my G35 and those things can lower my car to the ground on 19s.
Just look around in the marketplace I'm sure you can find a good deal.
INLS400
07-28-14 01:45 PM
harvi666
08-29-12 12:16 PM
lev00221
10-25-10 02:16 PM
GuitarJim
14
11-15-09 03:33 AM
vsynergy
06-24-05 10:56 PM
Quick Reply: Cut my coils to lower my ls400
