Please help, I think I fired my compressor!
Old Jan 18, 2011 | 10:46 PM
EN_VY's Avatar
EN_VY
Default Please help, I think I fired my compressor!
I meant fried
Ok, so my the braided steel line that goes to the compressor started leaking like crazy, up to the point that to keep air in the tank, Id have to keep the compressor on 85% of the time. This happened a few days ago, and I have only been going to work and back, and I live only 10 minutes away, so no problem here. I found a braided steel line in my garage which would leak just a little bit. So I asked a frined for advice, and I think I may have misunderstood him My braided steel line comes with a check valve on one end, and I had that side on the compressor, and the other end in the tank. I called my friend, and I misunderstood him, so I placed the end with the check valve on the tank.
I tunred the compressor on and went inside to get some soap and water. Maybe 3 minutes. As I walk outside, I take a look at my psi meter, and the tank is still at ZERO!! I go and spray some soap on the line but I get no bubbles So I look online for pictures of a compressor, and I only find compressor with the check valve side attached to it. My question is, did I damage my compressor? Will placing the braided steel line the wrong way damage something? My theory is that the compressor was pumping air, but since the check valve wouldn't let air flow in, it kicked it back to the compressor, which damaged it. Please help!
Old Jan 19, 2011 | 10:09 PM
rgarjr's Avatar
rgarjr
What does the compressor do right now, with the check valve installed the correct way?
Old Jan 19, 2011 | 10:31 PM
alwayzspeedin's Avatar
alwayzspeedin
fried like fLY-LICE
Old Jan 20, 2011 | 07:16 AM
EN_VY's Avatar
EN_VY
It wont air up the tank at all. I tried checking for leaks, but nothing. It sounds like it normally does, but it doesnt air up my tank. Luckily for me, I have another 480 which had a hose attached, and it's working. I'm tires of replacing that braided line, it alwys goes out on me!
Old Jan 20, 2011 | 07:59 AM
swtjlsy's Avatar
swtjlsy
Take the line off and see if air is coming out at all if not then it done.
Old Jan 20, 2011 | 07:46 PM
Chancellor's Avatar
Chancellor
EN VY - do your have a lot of issues with your system? I was thinking about going with UAS and Tein Comfort Sport on my 3rd gen.
Old Jan 20, 2011 | 09:45 PM
EN_VY's Avatar
EN_VY
I have alot of issues with my system, but don't let that scare you. I am a very careless person and didn't do maintanance on the air suspension, such as empty the tank from water and so on. You should have a very good ride with Tein CS As long as you get the installation done right the first time, and you empty the tank once in a while, you should be good.
Old Jan 21, 2011 | 02:45 AM
beez43's Avatar
beez43
its all in the install chance... all in the install..
Old Jan 21, 2011 | 04:29 AM
Schnitz's Avatar
Schnitz
Chance - research strut options for your car. From what I've read Teins don't go very low even with UAS.
Old Feb 13, 2011 | 05:15 PM
NVTHSLEX's Avatar
NVTHSLEX
EN_VY
Man, you have got a lot of issues throughout the ownership of the GS. Must be crazy repairing lots of the stuff. Seein where the money could have gone....ie GTE
Did you also add a water trap ?
Old Feb 14, 2011 | 02:54 PM
5t341th's Avatar
5t341th
how come ur braided hose leaks? too much movement or what
Old Feb 15, 2011 | 10:30 AM
I.B.dAt.Fo's Avatar
I.B.dAt.Fo
Might have damaged the piston seal. You can rebuild it or purchase a new compressor like Air Zenith OB2
Old Feb 15, 2011 | 10:39 AM
EN_VY's Avatar
EN_VY
I gave up on it. I put another compressor and somehow my + made contact with - and now THAT one wont kick on.. It will once in a while :/
Old Feb 15, 2011 | 11:10 AM
NVTHSLEX's Avatar
NVTHSLEX
Oh man, another compressor is coming in the near future .
potatomon
Jun 7, 2019 03:33 PM
HrdPrkDGS4
May 10, 2013 11:44 AM
batmbl
Jan 9, 2011 02:45 PM
flexspeed
Jul 30, 2009 10:14 PM
lbq
Jul 19, 2008 02:09 PM
