Easy Street Auto Pilot
Old Feb 26, 2010 | 12:40 AM
EN_VY's Avatar
EN_VY
Default Easy Street Auto Pilot
So Im about to pull the trigger on this Easy Street. I need something to display my pressure and have 1 preset. This kit seems to be the one. Anything else I need to buy? I currently have the regular UAS Kit. Im hoping I dont need to buy anything else. Im spending more than I originally wanted on air Any cons of this kit? A member also told me that it inflates your bag when it detects a huge leak to prest psi. How hard is install? I did the UAS install myself with the help of members here Here is a link http://www.summitracing.com/parts/AIR-27600/
Thanks guys!
Old Feb 26, 2010 | 10:03 AM
V8_Aristo's Avatar
V8_Aristo
Bippu
I think that kit comes complete with everything. If you're running 1/2 line, then the transducer (pressure sensor) fitting will fit. If you're running a different size line then you might want to call to see if they have the size you need.
Old Feb 26, 2010 | 10:21 AM
IcEnPinKi's Avatar
IcEnPinKi
nice..i'm looking to go on air in the next month or so.. i wonder how this compares to the dakota digital #DHC-2002 Digital Height Control / Height & Pressure Control.. http://www.dakotadigital.com/index.c...rod/prd131.htm
Old Feb 26, 2010 | 12:10 PM
Spyder78's Avatar
Spyder78
CL Folding 25,000
I've heard real bad things about that controller reference this thread
http://vipstylecars.com/forums/showt...ht=easy+street
also I've called the company before to get info about their products, their customer support is horrible, took almost 2 hours to reach somebody, no one returns messages, and unless you are purchasing a lot from them they dont care. But thats just my experience and opinion.
Old Feb 26, 2010 | 02:43 PM
IcEnPinKi's Avatar
IcEnPinKi
thanks vlad, i actually saw this post but i forgot which controller it was...i guess no easy street for me...
Old Feb 26, 2010 | 02:55 PM
V8_Aristo's Avatar
V8_Aristo
Bippu
I've had mine for almost 5 years with no problems. I also know of a few people that has them and haven't heard of it breaking down. Maybe me and those other people have just been lucky. I've had to call them a few time and even RMAed a faulty pressure sensor, no problem with that either.
Old Feb 26, 2010 | 03:57 PM
Spyder78's Avatar
Spyder78
CL Folding 25,000
That's good news, everyone has different experiences. I personally have not used this product so I cannot say how good it is, just going off of what is posted online plus my own experience with trying to reach them. However the best digital leveling system IMHO, is one that work off of height sensors rather than psi in the bags, since psi can fluctuate. Dakota provides either pressure or height or a system utilizing both. Accuair uses height. Those are the best systems currently on the market to my knowledge and experience.
Old Feb 26, 2010 | 03:58 PM
Spyder78's Avatar
Spyder78
CL Folding 25,000
No problem Will, sometimes you get what you pay buddy
Old Feb 26, 2010 | 05:56 PM
EN_VY's Avatar
EN_VY
Thanks for all the replies. Does anyone know of ANOTHER air management kit for around 600? I know its a long shot but maybe.. All Im interested in is having 1 preset, thats all I ask. I dont even mind using switches..
And for those with height sensors, are they noisy? How does it exactly work? I mean, roads are uneven so, wouldn't the sensors be working nonstop letting air in and out of the bags? Im confused
Old Feb 27, 2010 | 12:49 AM
Spyder78's Avatar
Spyder78
CL Folding 25,000
A height based sensor is essentially a potentiometer, it lets the ride controller know what height you are at by the resistance value that it puts out. Height sensors make no noise, Benzs, Caddys, Hummers, LS430 and many other air suspension and hydraulic equipped cars use them with no issues. However a quality air ride system I have never seen for around the price you are looking for. Sorry.
Old Feb 27, 2010 | 08:36 AM
EN_VY's Avatar
EN_VY
What about this one
http://cgi.ebay.com/ebaymotors/DAKOT...#ht_4557wt_924
More than I want topay but...
Old Feb 28, 2010 | 10:28 AM
Kohinoor's Avatar
Kohinoor
i have wired this system at least half a dozen times on most of RE's cars, including my own. its a great system IMO and very easy to set up. the people complaining of problems on vipstylecars cut the wire harness and extended it and also used them with other valves. my guess is they did something wrong along the way. i have used this system ONLY with autopilot valves. by using their valves, its all plug & play. i nor any of my teammates have had any problems.
by the way, its cheaper from guage
http://store.gaugemagazine.com/autop...pgradekit.aspx
autopilot valve manifolds (1 manifold per 2 bags):
http://store.gaugemagazine.com/autop...oldvalves.aspx
Old Feb 28, 2010 | 08:09 PM
EN_VY's Avatar
EN_VY
Thanks man. Do I need the manifolds? Or is it something extra. I have no clue, but I guess if I order this kit, ill figure it out
Old Mar 1, 2010 | 10:16 AM
Kohinoor's Avatar
Kohinoor
you can use your own valves, but im not sure how it wires up. using the manifolds will make it plug & play. it made my install as simple as wiring up some subwoofers.
Old Mar 2, 2010 | 02:26 AM
I.B.dAt.Fo's Avatar
I.B.dAt.Fo
I agree it is a great system and very easy to install. I saw their post on vsc also but i wasn't discourage in getting the system because of how they hooked it up. I do have small issue with the one touch ride height but its because of how I installed it and i hooked it up to airrunners manifold.
