Stretch Tire Guru's!!
Subscribe
Aug 7, 2008 | 07:27 PM
Ok, I'm about to pull the trigger for some Falken FK452s but I'm getting mixed opinions. Wheel size is 19x8.5 & 19x10, IMO I want to run 215/35 & 235/35 giving it a bit of a stretch but not too much. Is this a good stretch or overkill?
Reply 0
Aug 8, 2008 | 04:35 AM
235 on a 10 is a crazy stretch cause im runnin a 245 o a 10 looks crazy already..ur doing almost a 3inch stretch
Reply 0
Aug 8, 2008 | 05:59 AM
IMO, that would be a good stretch as FK452 runs a bit wider compared to other tire companies... but unless your running a +22 or lower, i dont see any reason to stretch on your isx50
Reply 0
Aug 8, 2008 | 06:08 AM
The stretch is cause I'm lower then you
Reply 0
Aug 8, 2008 | 08:37 AM
I used to run a 235 452 on my 10. They run pretty midland to wide so it wont be that much stretch. I have run as small as a 215 on a 10, but that was on the back end of a little paperweight car of a VW.
Reply 0
Aug 8, 2008 | 10:45 AM
meh, stretch 'em JUST enough to clear, no more, no less.
the point is to have the MOST tire for the aggressive offset, not the least....
Reply 0
Aug 8, 2008 | 11:00 AM
I have a friend thats running a 235 on a 10.5 thats how I figured 235 on a 10 is good.
Reply 0
Aug 8, 2008 | 11:12 AM
Quote: The stretch is cause I'm lower then you
wew...u on air now??? post some updated pics after you figured things out...
Reply 0
Aug 8, 2008 | 07:57 PM
Nigellll
Reply 0
Aug 8, 2008 | 08:05 PM
^^ where'd that come from? LOL
Quote: wew...u on air now??? post some updated pics after you figured things out...
Hey you hush! ahhaah
BTW I bought the tires today, so thanks for the input guys....
Reply 0
Aug 8, 2008 | 08:52 PM
thats a 245 35 on a 10inch wheels.pretty wild for me since i live in philly
Reply 0
Aug 9, 2008 | 07:37 AM
Im curious, does offset and size of the wheel change things? Cause you have 20s
Reply 0
Aug 9, 2008 | 10:09 AM
Depends on the brand of tires and the sidewall, they all run differently in regards to stretch.
here are some pictures to give you an idea from a really good thread in about this on VSC.
Toyo - 245/35/20 on a 10" rim [photo courtesy of widebodyq]
225/40 on a 10" [photo courtesy of ballin']
235/35 Falken ST115 on a 19x10 [photo courtesy of HoeBag]
Reply 0
Aug 9, 2008 | 11:50 AM
Well its Falken FK452s Wheel is 19x10 with a 44 offset
Reply 0
Aug 10, 2008 | 03:21 AM
Quote: Well its Falken FK452s Wheel is 19x10 with a 44 offset
which would again lead me to question why you really need to stretch at all with such a conservative offset
Reply 0
