TX Models (2024-present)
What is this noise.
Old Sep 8, 2025 | 06:42 PM
Damiendgonzalez's Avatar
Damiendgonzalez
2nd gear
Default What is this noise.
I just brought myself a 2025 TX 350 AWD premium. The vehicle has 114 miles. While driving and making a lengthy left hand turn this noises happens. Any one have any idea on what this might be. It’s not a consistent noise. Video attached.
File Type: mov
Old Sep 8, 2025 | 06:50 PM
Damiendgonzalez
2nd gear
This only occurs on a consistent left-hand to going approximately 10 miles an hour and not applying any brakes. Does not occur when doing the same motion for a right hand turn. It also stops once I allow the vehicle to straighten out.
File Type: mov
Old Sep 8, 2025 | 07:02 PM
That's not good. Possible brake pad issue or maybe dust shield rubbing on rotor. Or could be a number of things, it sounds like metal on metal. Back to the dealer you go.
Old Sep 9, 2025 | 03:34 AM
rutabox's Avatar
rutabox
I had a mystery noise too but different. It did translate into the cabin thru the steering and floor under engine load, often while turning into corners. I was certain it was the front suspension but was relieved.... have them check the exhaust hangers as I had a torn hanger and replacing it solved the noise issue. Good luck!
dean1947
RZ Model (2023-present)
Jul 20, 2025 09:15 AM
bigboat430
Jan 6, 2025 07:50 AM
nexilexi
NX - 2nd Gen (2022-current)
Aug 19, 2022 04:09 PM
ItsTheJag
Jun 5, 2019 02:00 PM
iyf350
Jan 10, 2011 01:38 PM
