TX Models (2024-present)
Third row seat popping during mid-fold?
Old May 29, 2026 | 03:39 AM
  #46
DonsCA's Avatar
DonsCA
I get what can be described as a popping, sometimes, when going up or down, and it is the cover for the cargo area in my case not being perfect with the seats. It is not a metal sound in my case, are you having a metal sound?
Old Jun 15, 2026 | 06:19 PM
  #47
Chade617's Avatar
Chade617
3rd Gear
Default Popping + Surface Rust?
Just picked up a gently used 2024 TX350 Premium and researching the popping noise brought me here. Upon inspection, I was surprised to discover quite a bit of surface rust on the seat frame itself. I get that untreated steel will oxidize almost immediately, but it caught me off guard nonetheless. I'm scheduling to have the popping noise addressed (along with a couple of other warranty-related concerns) and plan to bring this up with the service advisor, but wondered if anyone else has noticed this??
Old Jun 15, 2026 | 06:24 PM
  #48
tinmanwpk's Avatar
tinmanwpk
That really is inexcusable.
Old Jun 15, 2026 | 09:17 PM
  #49
websurfer's Avatar
websurfer
wow, I guess I'll check that out on the weekend also.
Old Jun 16, 2026 | 07:05 AM
  #50
G30540i's Avatar
G30540i
Wow, I would expect to see this on a Stellantis product, but a Lexus?! I’m going to look under the covers this weekend and please keep us updated on the dealer’s response to the rust. They’re probably going to tell you it’s “normal”
Old Jun 20, 2026 | 04:25 PM
  #51
Chade617's Avatar
Chade617
3rd Gear
Shocker, dealership said they compared the popping noise to other new TX's on the lot and deemed it a 'characteristic.' Also conveniently glossed over the surface rust question on the seat frame. Guess it's up to me to keep an eye on both over the balance of my factory warranty.
Old Jun 20, 2026 | 07:32 PM
  #52
websurfer's Avatar
websurfer
Exact same thing happened to my dealer,.
Old Jun 21, 2026 | 04:05 AM
  #53
Stonebender's Avatar
Stonebender
Shocking? How about just "surprising"?
The popping noise when raising/lowering the 3rd row seats in my TX500h has always been there and I'm not sure why its even a concern. This is a very minor noise and has never interfered with operation in any way.
Regarding surface rust on the mechanism - curious indeed. Your picture of corroded bare steel suggests exposure to quite a bit of moisture - but still - I'd have thought the structure would havd been surface treated (paint or galvanized, etc) or at least lubricated to guard against this. Not a great way to save money.
Old Jun 21, 2026 | 05:03 AM
  #54
Chade617's Avatar
Chade617
3rd Gear
I agree it doesn't interfere with operation and if it's truly a 'characteristic' then so be it. Having said that, it doesn't sound overly intentional and I've seen plenty of other power folding third row seats that don't suffer from the same. My concern is that whatever is causing the noise will prematurely stress or wear on a component that will eventually break. Apparently, I won't be alone if that's the case and Toyota has historically stood behind faulty design flaws even after years of service, so we'll just wait and see.
Regarding the seat frame rust, I was worried about moisture too, but the surrounding body panels and components appear pristine. I had an older generation Highlander that showed similar oxidation on the third row frame, but the vehicle was nearly 8 years old by the time I had a reason to dig that far under the carpet. Perhaps this is just another 'characteristic?' Time will tell.
Old Yesterday | 04:21 AM
  #55
lesh's Avatar
lesh
5th Gear
Originally Posted by Khanf
There is emergency release inside the car on the left side, but you have to pry off a plastic cover. Or you can take la drop of bicycle oil and coat the black rubber roubd thing and coat it and that should fix it temporarily
Lastly u can either install feltpad ot just stop by dealership and they should be able to fix it fairly quickly.
You dont want to be stranded on site of a road cuz u can open it.
My dealership had to order a new fuel door. It took weeks to get it and then they had to paint it to match my specific TX. It wasn’t quick, but at least it now works as intended.
Old Yesterday | 07:44 AM
  #56
johnpinnc's Avatar
johnpinnc
Same
Old Yesterday | 09:55 AM
  #57
tinmanwpk's Avatar
tinmanwpk
That's the reason I don't want a new door. I want the paint to match, so I will live with hitting the release button a few times to open it.
Old Yesterday | 09:22 PM
  #58
johnpinnc's Avatar
johnpinnc
My paint match is perfect
Old Today | 06:22 AM
  #59
tinmanwpk's Avatar
tinmanwpk
Excellent. I don't have that confidence.
Old Today | 01:37 PM
  #60
SeniorNotso's Avatar
SeniorNotso
Originally Posted by Stonebender
So you haven't "tried the Fix" ... yet? Please let us know how the repair goes and if it holds up. My seat pops on occasion, and I normally carry a full tub of gear in the rear cargo area - but no issues so far.
Correct, we have not had it fixed by Crown Lexus since it requires 2-3 days, (75 miles away) and we haven’t had to use the 3rd row since the 2 “kids” died. What surprises me by all these comments is that the noise is referred to as characteristic and normal by dealers is because that is their answer when they’re dumbfounded by what is making the noise and don’t care. Unless it’s not a safety issue, and they’ve got your $$, just suck it up and live with it and all the other noises to follow!
“Oh", it was purposely designed that way to draw your attention to the seat folding/unfolding. No difference to all the other poor design flaws on this vehicle. Just turn up the volume on the radio to drown out the cable “SNAP” !
Speed3381
Jan 21, 2022 05:19 PM
zriceman
RX - 4th Gen (2016-2022)
Aug 29, 2020 07:56 PM
MLindgren
May 12, 2017 06:35 PM
mikeivan
LX - 3rd Gen (2008-2021)
Aug 29, 2008 07:13 PM
