Gs300 with ls400 brakes, new pads and rotors keeps SQUEAKING!
Old 02-08-19, 08:36 PM
Sc3Hunnaa
Sc3Hunnaa's Avatar
Default Gs300 with ls400 brakes, new pads and rotors keeps SQUEAKING!
I have a gs300 with a ls400 brake set up the previous owner replaced with (he says) ceramic pads and drilled and slotted rotors (I checked they look brand new) I've put quite a bit of miles on it since so I dont think they still need bedded lol.
Okay, the answers probably very simple I know but I want to hear how you all fixed your issues to see the different things I should run through. Basically the front brakes squeak when stopping slow, if I brake moderately hard then they do not, when I let out slowly they'll squeak. If I stop moderately slow and hear them squeak I can let out a bit and reapply and they will stop. I dont think they're squeaking because they ceramic that's what the precious owner said because it sounds very unnatural and annoying lol
Old 02-09-19, 10:10 AM
kos
kos's Avatar
Ever think of going to a normal, blank rotor?
Old 02-11-19, 03:49 AM
Sc3Hunnaa
Sc3Hunnaa's Avatar
I have. They were on the car when I bought it. I was looking to see if some people had the issue and fixed it with things like a shim kit or hardware kit.
Old 02-11-19, 06:09 AM
kos
kos's Avatar
Your original post said that the car has drilled /slotted rotors on it, my recommendation was based off of that. If it has blank rotors on it now and the issue is still persisting, there's a few different ways you can go.
Old 07-25-19, 07:01 AM
Euro09
Euro09's Avatar
Remove the pads and lubricate the shim kit see if that helps.
Old 08-02-19, 12:06 PM
RA40
Super Moderator
RA40's Avatar
+1 about a bit of lube on the piston side of the shim. Also make sure the guide pins have a bit of lube but I've not noticed any difference with or without it. If the pins are bent, replace them.
https://www.lexussouthatlantaparts.c...773550010.html
Part#4773550010
tjnez
Suspension and Brakes
06-25-13 02:20 PM
calanm
02-09-04 09:00 AM
robbsneak
Maintenance
07-02-02 06:10 PM
rsg
06-28-02 10:39 PM
Quick Reply: Gs300 with ls400 brakes, new pads and rotors keeps SQUEAKING!
