will this fit on a 92 LS?
i'm wondering if the 245 in teh rear might be a bit too much stretch... maybe 255s instead? i do drive the car regularly, so it needs to be safe!
http://www.fabulous.co.jp/products/l...dan/celsior10/
f - 19x9 + 36 special low disk
r - 19x10.5 +3- special low disk
f - 19x9 +5 low disk (+25 offset w 20mm spacer)
r - 19x10.5 +5 super low disk
rolled fenders
f - 19x9.5 +35
r - 19x10.5 +24
not sure about fender work
+35 on a 9.5 inch wheel works, while +5 on a 9 inch wheel with a fender pull does not... 30mm is just over an inch (25.4mm is 1 inch), and it seems to make a huge difference.
+24 should be doable, provided you're willing to modify the fenders and have the car low enough to pull off the look.
cool, thanks guys. i ordered them and they should be here monday... i decided to go with the 255 35's in the back. i have no problem modding the fenders, it won't be the first time i've had to cut fenders!
trill2go
SC- 1st Gen (1992-2000)
09-19-08 10:44 AM
happypanda
Suspension and Brakes
26
07-09-05 09:16 AM
