Rim experts... please help...
i have a stock 2000gs and i am planning to get 20's.... i would still like my ride quality as close to stock as it can be with 20's...i do not race or drive hard..i just cruise.. i need little more information before i do this...
1. i will be getting the tein cs coilover for this project
2. trd or daizan sways? (i heard some people have this but do i need this?)
3. whats a good offset setup for this for front and rear?
4. would you recommend geting aftermarket springs and shocks since im getting coilovers? or is this setup ok with the stock?
5. how about the suspension?
this is all i came up, please add anything to my list or if i had miss anything. let me know your ideas and recomendations.. thank you
The One
2. If you are OK with the current handling, then you don't need this. If ride quality is important and you want sways, then go for Daizen.
3. See here: https://www.clublexus.com/forums/sho...d.php?t=115165
4. Coilovers replace the OEM shocks and springs. The coilovers are all you need.
5. Again, unless you want to beef up handling, you do not need these either. Try the wheels with the Tein CS first and see how you like things.
Keep in mind that the ride will never be like stock. Going from 16s (or 17s) to 20s, you lose rubber sidewall. With less (and stiffer) rubber, you get less cushioning. The best you can do is to minimize ride quality loss.
exclusive matchup
Originally Posted by cliffud
just to add to what Chris mentioned, you'll feel less body roll with bigger wheels since the sidewall is thinner. with that in mind- you may not feel the daizen sway bars are necessary unless you go for fast cornering.
one more thing regarding the offset.. for example if it is : 20x8.5 +38 20x9.5 +38, what does the +38 mean?
this is regarding the tein edfc, i was reading about it but i just got get whats it for... ? where would this go on my car?
The One
Tein EDFC controls the shock valving of Tein coilovers. From your POV, It basically controls how stiff or soft the ride is.
