taking apart 3 piece wheel Help
i have the lowenhart LR5 im trying to take it apart so i can have the lip rechromed. I already removed all teh riviet bolts. anyone know how to remove the face off the wheel off the rim?
Originally Posted by rominl
the outter and inner wheel (the cylinders). seems like they are welded together
I hope you don't call that hammer pictured a rubber mallet
Yeah, the outer and inner barrels are the other 2 pieces...
Usually there's a nice thick layer of silicon that lines the 2 pieces. Do you have the torque settings for when you put it back together? I've always wondered if there is a certain amount of pressure needed or just hand tight would do the job?
Originally Posted by Din
nvm figured it out. Got me a rubber mallet
I know its 3 piece, where would the other piece be?
exclusive matchup
i have no idea what the torque setting is.
Anyone know? What are teh steps in putting it back together? I heard you gotta torque it a certin way.
exclusive matchup
haha na the rubber mallet isnt in the picture.
exclusive matchup
Originally Posted by IS0LD0UT
i have also heard that when you take a multi-piece wheel apart, the studs should be replaced too. Aparently the stress from tightening and untightening could make the studs weak.
