Any difference in ride between 20" or 19" wheels?
I am trading out my hideous 20" wheels this week. I am also going to be lowering my car a bit with L-tuned shocks and springs. I started thinking that maybe I should get 19" wheels instead of 20" to save the ride a little bit, especially since I am changing the suspension. My question is, will it even matter to downsize 1 inch, or should I just stick with the 20s as the combination will just make the ride rougher anyway?
-Kendre
-Kendre
Guest
Posts: n/a
-Kendre
-Kendre
If anything makes the ride rougher, its adding TRD Blue sway bars and any suspension bars, b/c they make the car much stiffer.
Former Sponsor
if you use the normal 19 setup (245/35, 275/30) and the normal 20 setup (245/35, 275/30), then yes the ride is the same. If you go with the "fat" 19 setup (245/40, 275/35) then you will have a better ride on the 19s. If the roads are not absolutely horrible where you live then 20s will be fine.
As information, the L-Tuned drop only degrades the ride by about 10-15%, nothing major at all.
Have fun!
Have fun!
Lexus88
04-18-18 11:02 AM
