Another offset question
Old 03-16-04, 07:58 PM
minh
minh's Avatar
Default Another offset question
18x8 front 18x9 rear +45 offset. Hows is that gonna fit on a first gen gs300? Thanks.
Old 03-16-04, 08:23 PM
DVSG3
DVSG3's Avatar
Unhappy
Can someone explain offset. Is that how far out the wheel sits off the axle or where the center of the tire is located compaired to the axle. Thanks. Remedial I know, but I am a noobie to this.
Old 03-17-04, 12:07 PM
johnee78
johnee78's Avatar
Default Offset
Rule of thumb.The higher the offset number the more tucked in the wheel will be.The lower the number the more it will stick out.As for the 45 offset that you are asking about, it should fit but it may look tooo tucked.The rear should be fine.Worst case scenario run some 5mm spacers in the front to bring it out.
Old 03-17-04, 12:43 PM
rominl
exclusive matchup
rominl's Avatar
both front and rear are way too high offset imho
Old 03-17-04, 01:33 PM
minh
minh's Avatar
I don't have an aversion to spacers. what size should i use front and rear to make this setup work? TIA.
Old 03-17-04, 01:58 PM
Pianoman72
Pianoman72's Avatar
Default check my homework
on minh's rear wheels
The clearance from stut housing to the inside of the wheel will be 14mm LESS
The outside edge of the wheel will EXTEND an extra 24mm
http://toy4two.home.mindspring.com/offset.html
Old 03-17-04, 09:48 PM
ATSOU
ATSOU's Avatar
Offset is the number in mm which represents the distance between the center hub of the wheel to the center line of the wheel width (half of the wheel.)
Old 03-17-04, 10:18 PM
rominl
exclusive matchup
rominl's Avatar
http://www.tirerack.com/wheels/tech/offset.htm
sometimes search on the internet is very helpful
moose66
10-23-11 01:43 PM
cm09578
IS F (2008-2014)
08-13-09 03:01 PM
phillygs3
11-15-07 10:42 PM
iamkhanz
07-07-07 06:47 AM
hitechgs3t
02-15-03 02:43 PM
Quick Reply: Another offset question
