Suspension Springs, shocks, coilovers, sways, braces, etc.
replace struts-2011 GS350 Rear wheel drive
Old Apr 1, 2020 | 01:41 PM
lswenson5's Avatar
lswenson5
Default replace struts-2011 GS350 Rear wheel drive
I am looking at replacing the stock suspension due to age\miles on car (108,000) as part of routine maintenance. What is the best option? Not looking to lower car, nor am I needing more aggressive cornering. Would prefer an "easy-strut" if able, where the strut and coil spring come together. Open to ideas and suggestions.
Old Apr 4, 2020 | 06:12 PM
sha4000's Avatar
sha4000
You should probably post this in the regular forum since this forum does not get much traffic. I'm pretty sure you will get more responses.
Old Apr 9, 2020 | 02:19 PM
gs350fan's Avatar
gs350fan
Rears are leaking on mine.
There are no EZ struts. Autozone will ship you a free rental compressor, then return to a store. I bought the KYB mounts from them and the shocks from Rockauto (good price).
I have the AWD version. Rear is identical to RWD. Front RWD looks identical to my old Tbird, same strut. You have to remove the UCA, and work the strut bolt out of the LCA. AWD front is a bit different.
I suffered with the shock bushing bolt but that is normal where I live, and I'm experienced with it. I had the car in the garage for a few days and worked on it a bit every day. The rust causes it to bind and you need rust penetrant, curse words, powerful air/electric impact tools to spin it out. Shops add 100-200$ for this.
Install is tricky, things have to be lined up just right with the rear LCA and strut. It is a tension fit.
BA777
Mar 23, 2016 06:05 PM
gs350RWD
Aug 1, 2012 05:44 AM
noncom23
May 16, 2011 12:29 PM
Terrapin
Nov 5, 2005 12:17 PM
