Suspension Springs, shocks, coilovers, sways, braces, etc.
Slight wobble while lowered
Old Jul 4, 2019 | 08:11 PM
silverlake's Avatar
silverlake
Default Slight wobble while lowered
I have tanabe front springs and I had no wobbles at all just slight vibrations and now I installed 30 mm rca blocks and I get the wobble around 20mph then I usually lef off a bit and it settles would the blocks have caused this ? Or just the new struts and springs finally settled ?
Old Apr 23, 2020 | 11:31 PM
Geezey617's Avatar
Geezey617
did u figure out the right set up did u leave on da rca?
Old Apr 24, 2020 | 08:03 AM
silverlake's Avatar
silverlake
yes I removed the rcas I think if I would have had the 20mm it would have been fine i personally think with the drop from the springs and then adding these it over extended the knuckle in a reverse way because it was more then the initial drop from springs but it got better but there’s no fix per say it still vibrates at stops but not to the point where I’d remove them altogether
PNWdude
21
Jan 10, 2020 12:52 PM
Hayk
15
Jan 4, 2017 05:41 PM
ChadsGS400
Suspension and Brakes
Feb 6, 2016 09:12 PM
baddis es
Oct 16, 2014 06:01 AM
SptDsgnGS
Jul 8, 2009 12:12 PM
