Sage REAR RCA Install Pics
Hi Folks..
After 6 mos of road testing, I figure it was time to post up the install process of the Rear RCAs. I am running these on stock suspension. I couldn't tell you exactly how much negative camber this applied to the tire. It is slight, but this kit does offer you three different bracket placements, that could push in, push out or leave the tire angle flat. I had to push my tire angle in wards to avoid hitting my top fender walls, which I still do on occasion since my tires are overspec. I haven't had any issues running these rear RCAs or front RCAs either. On wards to the progression of the install. Car mounted and rear rotor supported ready for removal. http://img.photobucket.com/albums/v4...t/2RearRCA.jpg Removing the stock bolts http://img.photobucket.com/albums/v4...t/4RearRCA.jpg Bolts removed http://img.photobucket.com/albums/v4...t/5RearRCA.jpg http://img.photobucket.com/albums/v4...t/6RearRCA.jpg http://img.photobucket.com/albums/v4...t/7RearRCA.jpg Putting on the bracket http://img.photobucket.com/albums/v4...t/8RearRCA.jpg http://img.photobucket.com/albums/v4...t/9RearRCA.jpg Screwed in bottom bolt http://img.photobucket.com/albums/v4.../10RearRCA.jpg http://img.photobucket.com/albums/v4.../11RearRCA.jpg Now ready for the top bolt http://img.photobucket.com/albums/v4.../12RearRCA.jpg Notice how top bolt block has a hole for the top bolt? You can flip that block around to make the hole towards the car, this placement will push the angle of the tire slightly outwards. There is also a another set of block inserts where the bolt hole is straight in middle for a flat tire angle placement. http://img.photobucket.com/albums/v4.../13RearRCA.jpg Screwing in the top bolt http://img.photobucket.com/albums/v4.../14RearRCA.jpg http://img.photobucket.com/albums/v4.../15RearRCA.jpg And that's about it to installing these brackets.. I personally couldn't do it since it I don't have the tools to raise the car. I suppose someone with keen car skills could do this themselves. Unfortunately that isn't me. I got this done at Johnny's Auto Center in San Marcos.. that's the owner's car on the left and the person that did the install. His GS is sicker than MINE. http://img.photobucket.com/albums/v4...ut/Johnny3.jpg http://img.photobucket.com/albums/v4...hnny1_PLUG.jpg Before Pic http://img.photobucket.com/albums/v4...nut/B4Rear.jpg After Pic http://img.photobucket.com/albums/v4...t/RearTire.jpg |
Thread from my previous post for Front RCA install.
https://www.clublexus.com/forums/sus...p-install.html |
looks great:thumbup:
glad to see these are an option now. great way to give your car that lowered look and stick with the OEM suspension. I was rather impressed with just the fronts. Now its time for an AWD owner to test a full set up to see if they get the wobble. I bet this will work:) |
Is that a non-awd? Has anyone with AWD done this? I know the AWD has more wheel gap than RWD.
Originally Posted by vadimo
(Post 7627663)
Looks good. How much of a drop did you go with in the rear? Where did you get them and how much?
What wheel/tire size are you running?
wow that looks sick!!
And i am in Oceanside! :woohoo:Local +! Super excited since i just got my first GS 2 months ago. 3 questions: 1. Did Johnny's have the RCA's ? 2. How much was install? 3. What is his address/tel? thanks in advance! |
Originally Posted by adamz28
(Post 7628252)
Rear 20X10.0 O-Disk et 45mm Tires: Hankooks Evo110 V12 245/35/20 and 275/30/20 |
hows the ride over harsh roads?
Are you still running the 25 mm on the front?
Originally Posted by uncandid
(Post 7658272)
Originally Posted by N77NXC
(Post 7667113)
